Mk5 electronic throttle pedal
Postby Mark_C » Tue Apr 18, 2017 2:46 pm
Hi,
I need an early (2 plug) electronic throttle pedal to fit a 1997 mk5 2.5td with Epic.
Can't find any in Australia, so if anyone has one they are happy to post, please let me know, or could get it sent to friends or relatives in the U.K.
Mark
Regards
Mark
Mark_C
Re: Mk5 electronic throttle pedal
Postby Kev1000s » Tue Apr 18, 2017 5:46 pm
Hi,
think i have one,will check in morning
Regards Kev
Ford FDS 2000
52 plate , Smiley 150lwb ,Td,Ex police :)
1996 Smiley 100 ,Td-Intercooled , lowered 50mm,mk6 wheels,lsd 4.11..
Kev1000s
Postby MinorMatt » Tue Apr 18, 2017 7:36 pm
If kev hasn't I definately have, but can't get to it for a while
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Mark_C » Wed Apr 19, 2017 8:38 am
Thanks, let me know if you find one
I would like to do a bosch conversion, but getting the parts together from Australia is almost impossible, so I am hoping the throttle pedal will get me out of trouble, I have engine light on and it randomly goes into limp mode, otherwise usually runs well, it has only done 150,000 km and being an ozzy van has no rust
Regards
Mark
Mark_C
Postby Kev1000s » Wed Apr 19, 2017 6:56 pm
Mark the one i have is single plug, so no good to you, Matt will sort you out.
Regards Kev
Ford FDS 2000
Kev1000s
Postby MinorMatt » Sun Apr 23, 2017 9:38 pm
I *might* have one in the garage - if I do I can put my hands on it tomorrow. If not I have one in my workshop, but can't to it for a while
93 L GL Minibus
Postby Mark_C » Mon Apr 24, 2017 7:51 am
Thanks Matt
Let me know if you have any luck
Regards
Mark
Mark_C
Postby MinorMatt » Mon Apr 24, 2017 9:29 pm
2 pedals in the box here, but both are single plug.
I will find one at the workshop next time I am there, bri g it back and stick it on my van to test before shipping it...
93 L GL Minibus
Postby Mark_C » Thu May 04, 2017 1:05 pm
Hi Matt
Just wondering if you managed to find a pedal in your workshop yet?
Mark
Regards
Mark
Mark_C
Postby dots46 » Fri May 05, 2017 9:04 pm
Does anyone have a mk5 single, 8 pin electronic pedal please? Pretty sure mine is knackered but taking to a friends at the weekend to confirm.
Doug
dots46
Postby MinorMatt » Sun May 07, 2017 4:21 pm
Mark_C wrote:Hi Matt
Mark
Unfortunately the only one I found is a known faulty one :(
93 L GL Minibus
Postby Kev1000s » Sun May 07, 2017 5:29 pm
i have a single plug pedal ,know its good drove van 200 mile, removing as doing a bosch conversion..
Ford FDS 2000
Kev1000s
Postby dots46 » Mon May 08, 2017 8:36 pm
Sorted now, many thanks
dots46
Postby ernie b » Sun May 21, 2017 1:42 pm
Are you still looking by any chance Mark?
Forgot I had this, removed from a 96 100ps with a faulty epic.
Was working when removed but has been on the shelf a while
ernie b
