Mk7 BE RCM Please
Re: Mk7 BE RCM Please
Postby Trannyjohn » Mon May 18, 2015 3:00 pm
Cheers loot your a star
Trannyjohn
Postby Lucky-Charmer » Mon Sep 26, 2016 9:56 am
Can anyone show me where this module is please.
I have the same problem..... airbag light is flashing and codes read seatbelt pretensioner & passanger airbag (i dont have a passanger airbag)
please help as i need to get the letters off it to replace with a new or second hand one.
Lucky-Charmer
Postby loot » Mon Sep 26, 2016 12:43 pm
Above the clutch pedal :-)
65 290 2.2 125ps custom with 2 side doors yes 2 8)
07 350 170ps lwb mh AKA snowflake sold but not forgotten :-)
M radio codes here
Ids map here
loot
Postby Lucky-Charmer » Mon Sep 26, 2016 4:43 pm
Thanks martyn
found it, hopefully the dam light will go out with a replacement
Lucky-Charmer
Postby loot » Mon Sep 26, 2016 4:53 pm
Have you got ids?
M radio codes here
Ids map here
loot
Postby Lucky-Charmer » Mon Sep 26, 2016 7:55 pm
Garage already cleared them to see if they were just being glitchy (didnt help)
passanger airbag & seatbelt pretensioner (dont have passanger airbag on this model)
Hope its just the Restrainst module (SRS?)
Lucky-Charmer
Postby loot » Mon Sep 26, 2016 8:21 pm
Somehow the rcm has been configured :|
You can reconfigure it with ids back to single airbag.
It is possible it has developed a fault but you need someone handy with ids to look.
You can however also fit another single rcm, i thought they needed programming to the van but apparently they are plug and play.
M radio codes here
Ids map here
loot
Postby Lucky-Charmer » Tue Sep 27, 2016 8:29 pm
wishing you were local
Lucky-Charmer
Postby loot » Tue Sep 27, 2016 9:51 pm
Hmm, I've sent an rcm to daveyjcb that i set to single and the plan was that he send me his and the fiver i spent on postage but that was weeks ago :-(
He's either forgot or hates me.
So I'm down 35 pounds.
I've got 1 more rcm that i also paid 30 quid for but I'm a bit put off by it all.
However, I'm happy for you to send me yours and a fiver for postage and I'll reset it to single for you free.
Best i can do tho and it may mean that you are off the road a week.
There's 2 connectors and 3 x 10mm nuts holding it on, it would have been better to just swap them over but that option is spoilt :-(
M radio codes here
Ids map here
loot
Postby t0m541 » Sun Oct 09, 2016 9:18 am
I've managed to get my 101.3 IDS working and now have module reprogramming working,
I downloaded the configuration files and it shows that the vehicle has only drivers airbag but still getting the DTC's for passenger airbag fault.
How do I reconfigure the RCM to single airbag.
Loot you said that you can switch stuff on and off in the module reprogramming section, how is it done ?
When I highlight the sections in the list, some have dropdown menus, some dont, the cruise one doesn't neither does the passenger airbag.
'56 plate 2.2 Mk7 in white, EGR deleted, leather seats LED lights all round with HiD headlights
t0m541
Postby loot » Sun Oct 09, 2016 10:20 am
Not a config option it's a rcm reprogram.
I've already told you tom.
viewtopic.php?f=18&t=168536&hilit=Reconfigure+rcm
M radio codes here
Ids map here
loot
Postby Mooney1872 » Tue Mar 21, 2017 7:28 pm
Hi there my airbag light is also permantly on with the ids showing 3 rcm faults B1342 ,B1881 and U0155 all followed by RCM.I have tried to reconfigure RCM module but fails constantly an ideas thanks.
Mooney1872
