I too am lacking the bracket. I destroyed the one on a Mk4 getting the lever off as I coudn't figure out how the hell you get it off.
I'm planning to fabricate my own and pop rivet it to the bonnet... Mine is missing too. It was held in with a nut and screw, but the vibes eventually worked the screw loose and I lost the lever
The connecting rod is just a rod. Get some cheap tent pegs and you could probably fabricate one up. Cheap tent pegs can be cold bent with pliers, and then heated red hot and allowed to cool to re-temper them. Or indeed heated red hot and then bent, if you prefer that, but they're pretty mild steel and tend to bend easily cold. Can get you photos tomorrow of the bits, and will do photos for the bit I'm fabbing up whenever I get round to it i,e, probably this weekend if the weather is good... It bugs me having a bit of wire hanging out of the front of the bonnet to open it. I want it sorted, because it's the kinda crap VOSA might hassle me about if they stopped me again
PS the 'bearing' on the lever is just two large plastic washers, kinda this shape but nowhere near to scale.. The sticky out bits fit in the large hole in the middle of the lever. And presumably a similar sized hole in the bracket (which I destroyed and therefore don't have. How the hell does that bracket get in and out of the bonnet? I figured I could make one and so destroyed it to get the lever).
- Code: Select all
_____
_[ ]_
[_________]
Bracket it sits in is kinda shaped like this and roughly 1cm high, at least that's about the size it looks. It's not a precision component, long as the bonnet still shuts and the lever works ...
- Code: Select all
__
__[ ]__
PPS I must warn you, I got really shitty grades in Metalwork at school because I was never precise enough or methodical enough
