Wanted Urgently: Wheel nuts and studs for Mk 5
Postby mbassil » Tue Nov 22, 2016 11:30 am
Hello
We need wheel nuts and studs for a Mk 5 (we need 5 of them).
Thanks very much
mbassil
Re: Wanted Urgently: Wheel nuts and studs for Mk 5
Postby Altransit » Tue Nov 22, 2016 12:32 pm
Have you tried your local Ford dealer :?: They weren't that expensive the last time I had to buy some for my Mk5, and may be the answer if you're in a rush :idea:
Postby mbassil » Tue Nov 22, 2016 12:42 pm
Hi
Thanks, but yes we have. They don't have them. They said they'd have to see if they can get them from Ford and that would take at least 5 days if Ford even still supplies them (the van is very old - 1996).
mbassil
Postby Altransit » Tue Nov 22, 2016 12:57 pm
That's a rubbish dealer :!: My local one will get parts in, either later that day, or the following day, particularly if the vehicle is off the road needing the parts :roll:
Maybe worth phoning a larger dealer :?: :idea:
Postby mbassil » Tue Nov 22, 2016 1:56 pm
Who is your dealer? Noticed you're in Bicester. We're only in Whitchurch so not far for us to travel.
mbassil
Postby Altransit » Tue Nov 22, 2016 2:34 pm
There's a Ford commercial dealer, Hartwell, in Abingdon, 01235 522822 , which is closer to you, or even Hartwell in Kidlington 01865 290300, who would be more likely to have them in stock. My local guy gets his parts from one of those two anyway.
Tomo's in Uxbridge
http://www.tomoparts.co.uk/index.php?ma ... contact_us
are also a good source of spares, but are a bit further away from you
Postby greenmini » Wed Nov 30, 2016 8:34 am
hi there I have some mk5 studs from a single wheeler, new in the bags, can supply nuts aswell if needed drop me a text 07808701361 graham
greenmini
