Mk 6 swb wiper mechanism
Postby bigtaloola » Mon Apr 10, 2017 3:08 pm
Hi any one got a GOOD wiper mechanism no drivers side arm wobble
they tend to get very loose
Lichfield Area :D
bigtaloola
Re: Mk 6 swb wiper mechanism
Postby stevo » Mon Apr 10, 2017 3:10 pm
Try the transit centre in Dudley mate. Not too far from Lichfield, they'll probably post it to you.
Formely ibanez2005
Your's is the new Ford Transit!
2003 100 T260 TDDi swb
stevo
Postby Altransit » Mon Apr 10, 2017 3:41 pm
Unless you're very lucky, second hand ones are likely to be just as bad as yours, I bought two before I realised :( :oops:
:idea: I drilled out the worn bush on one of the 2nd hand ones I had, and fitted a new piece cut from a piece of brass tube that just fitted over the wiper spindle. I pressed the tube, using a vice, into the hole that I had drilled in the old bush, which was the size of the O/D of the brass tube.
It worked fine, and is still there 3 years later with no 'wobble'
Postby bigtaloola » Mon Apr 10, 2017 10:21 pm
Thanks for your input drilling sounds good
cheers Dave :D
bigtaloola
Postby bigtaloola » Sun Apr 16, 2017 5:44 pm
Hi I have drilled out wiper end took drivers side off and sleeve it with plastic pipe. That I heated up to get a good grip on drivers mechanism now 100% when replaced it all :D
thanks for you help
Dave
bigtaloola
Postby Altransit » Sun Apr 16, 2017 11:26 pm
Not sure that plastic pipe will last too long before it wears away again, but good that you have it sorted for almost nothing :mrgreen:
8) 8)
