Mk 6 swb wiper mechanism
Postby bigtaloola » Mon Apr 10, 2017 3:08 pm
Hi any one got a GOOD wiper mechanism no drivers side arm wobble
they tend to get very loose
Lichfield Area :D
bigtaloola
Re: Mk 6 swb wiper mechanism
Postby stevo » Mon Apr 10, 2017 3:10 pm
Try the transit centre in Dudley mate. Not too far from Lichfield, they'll probably post it to you.
Formely ibanez2005
2003 100 T260 TDDi swb
stevo
Postby Altransit » Mon Apr 10, 2017 3:41 pm
Unless you're very lucky, second hand ones are likely to be just as bad as yours, I bought two before I realised :( :oops:
:idea: I drilled out the worn bush on one of the 2nd hand ones I had, and fitted a new piece cut from a piece of brass tube that just fitted over the wiper spindle. I pressed the tube, using a vice, into the hole that I had drilled in the old bush, which was the size of the O/D of the brass tube.
It worked fine, and is still there 3 years later with no 'wobble'
Postby bigtaloola » Mon Apr 10, 2017 10:21 pm
Thanks for your input drilling sounds good
cheers Dave :D
bigtaloola
Postby bigtaloola » Sun Apr 16, 2017 5:44 pm
Hi I have drilled out wiper end took drivers side off and sleeve it with plastic pipe. That I heated up to get a good grip on drivers mechanism now 100% when replaced it all :D
thanks for you help
Dave
bigtaloola
Postby Altransit » Sun Apr 16, 2017 11:26 pm
Not sure that plastic pipe will last too long before it wears away again, but good that you have it sorted for almost nothing :mrgreen:
8) 8)
Users browsing this forum: Grahamec
