MK6 ASM (Durashift) Clutch Actuator wanted
Postby ITECH » Mon Dec 18, 2017 11:57 pm
Hi.
Anyone got one of these floating around please?
Part No 1C1R-7A508-CB (or CE)
equiv 1450562
2.4DI RWD Mt75
Quite happy to pay freight. Not happy to pay silly prices...
If all else fails, will convert to manual. ‘tis cheaper... But then I’ll want to put in a MK7 dash to get my floor area back.
Van is reliable and sound. Extremely dodgy work done on it prior to me though - ex rental camper van so you’d ‘think’ it would be professionally serviced, but no... Is why the $3 plastic actuator guide was split & sh@t itself when I reinstalled it after a flywheel / clutch etc swap.
Also looking for:
1. lower steering shaft Flexi bolt & circlip (was snapped off) (not available from Ford New Zealand)
2. plug & heatshield for crankshaft position sensor (broken plug clip, probably ‘cause it wasn’t removed before the gearbox was pulled by a prior ‘professional’.
Many thanks.
2002 LWB Hi-Roof ASM 90 (New Zealand)
ITECH
