Propshaft for mk5 100 LWB
Postby Catjenkins » Tue Apr 03, 2018 4:22 pm
Propshaft for mk5 100 LWB wanted I'm in North Wales I'm not sure if one off a 190 is the same does anybody know?
07563854340 text if no answer I work nights
Catjenkins
Re: Propshaft for mk5 100 LWB
Postby bambi mk 1 » Tue Apr 03, 2018 10:39 pm
Back end is shorter due to bigger diff on a 190,rest is the same.
Theres the good guys,theres the bad guys but there only ever be one SPEED GUY
bambi mk 1
Postby MinorMatt » Fri Apr 06, 2018 1:56 pm
Length is the same... the flange on the back may be different dependant on what the factory fitted to yours
96 N 120 Turbo'd DI SWB Low
97 P 150 76PS Di SWB low ex essex police
Lucas laser 2000 & IDS onwner
Postby bambi mk 1 » Fri Apr 06, 2018 8:46 pm
MinorMatt wrote:Length is the same... the flange on the back may be different dependant on what the factory fitted to yours
A 100l rear shaft on a 190 will push the engine fan into the rad Matt :wink: They are different lengths :)
bambi mk 1
Postby Catjenkins » Sat May 26, 2018 6:38 am
Ok thanks for the info
Catjenkins
Postby B4ndit » Sat May 26, 2018 7:43 am
Is this one the same
B4ndit
Postby Catjenkins » Sun Jun 03, 2018 6:49 pm
Sent pm B4ndit
Catjenkins
