Steel wheels
Steel wheels
Postby Steve192 » Thu Aug 16, 2018 9:44 am
In need of a set of standard steel wheels for a mk7 Transit. With tyres.
Cheers
Steve192
Re: Steel wheels
Postby Altransit » Thu Aug 16, 2018 10:11 am
15" or 16"?
Re: Steel wheels
Postby Steve192 » Thu Aug 16, 2018 10:46 am
Preferably 15”if poss. But would consider 16” if the tyres are mint
Steve192
Re: Steel wheels
Postby Altransit » Thu Aug 16, 2018 11:23 am
I have a set of 16" shod with nearly new Michelin Agilis tyres, 215/75/16c
Standard on a 330 or 350, but I used them for a short while on my 280 Mk6, without any problems.
Re: Steel wheels
Postby Steve192 » Thu Aug 16, 2018 12:01 pm
Did that tyre size on the 16” raise the van up? They seem massive them tyres.
How much you after? And where about are you?
Steve192
Re: Steel wheels
Postby Altransit » Thu Aug 16, 2018 12:15 pm
They will raise the van a little, and they will drop the revs in any gear, and make your speedo under-read, because they have a 10% bigger rolling radius. They worked for me as the van was always loaded, and gave me less sway when cornering.
Re: Steel wheels
Postby Steve192 » Thu Aug 16, 2018 9:28 pm
I’m after 15”s really mate but thanks for the offer.
Steve192
Re: Steel wheels
Postby Digrizrat » Wed Sep 12, 2018 2:45 pm
Altransit wrote:I have a set of 16" shod with nearly new Michelin Agilis tyres, 215/75/16c
Did you have the 215/75r16 on the front as well as the back of your 280? I'd guess the front would be more prone to rubbing with larger tyres. I'm still plotting to upgrade my 280 mk7 when the 195/70r15 finaly wear out.
Digrizrat
Re: Steel wheels
Postby Altransit » Wed Sep 12, 2018 5:08 pm
Digrizrat wrote:Did you have the 215/75r16 on the front as well as the back of your 280? I'd guess the front would be more prone to rubbing with larger tyres. I'm still plotting to upgrade my 280 mk7 when the 195/70r15 finaly wear out.
Yes, all four were on there :)
Re: Steel wheels
Postby Digrizrat » Sun Sep 16, 2018 9:18 pm
I'm sold. I assume as it's the standard size on the heavier vans, meaning I should be able to set it int he computer.
Digrizrat
Re: Steel wheels
Postby Altransit » Sun Sep 16, 2018 10:15 pm
Yes, it's the standard wheel size on a 330fwd, which is essentially the same sized van, (albeit carries more weight!)
These will make the speedo under-read by about 5%, instead of the normal 5% over-read, which can be corrected with IDS :D
