anti-tramp bars
Re: anti-tramp bars
Postby Terry » Sat Apr 11, 2009 5:00 pm
Glad they do the trick ,you are gonna hate me for this. But for the Mk2 pair why dont you mount the brackets that you have welded onto the axle casing above the axle, run your links forward, and make the bracket for the front shorter, that will reduce your ground clearance problems (looking at your pics there seems to be a fair amount of space above the axle. This would have (all but) given you a 4 link set up (and 4 out of 5 ain't bad :) )
Just for future consideration, there is no reason why the 'links' cant run backwards to the rear of the vehicle (usually the links are on vehicles with a 'less strong' chassis rails or none behind the suspension mounting points).Neither do they NEED to be parallel with the ground. On the old Lotus Cortinas the bars were all but (in plan view) a W shape ,the mount for the centre upper of the W was welded to the axle casing below the diff, thats why they used to rip out so easily,one mount trying to do the job of 2.
H.T.H.
Terry
Pallet Puller
Terry
Re: anti-tramp bars
Postby Luke » Sat Apr 11, 2009 5:06 pm
Tony's is the mk2 so he could do it that way :lol:
the reason i went for undeneith is if you take the spring clamp as the pivot point you get more leverage that way - to get the same effect if you mounted them on the top you'd need to go 3-4" taller on the axle mounts i think it could be done and you'd almost have the link bars mounted on the chassis rails right up to the floor :)
one advantage (convincing myself) of the bars dropped down is if i hit a kerb or something it'll stop damage to the side pipes :lol:
Re: anti-tramp bars
Postby Terry » Sat Apr 11, 2009 6:55 pm
Hi Luke,
Where do you mean when you say the spring 'clamp' the U bolts or the front spring 'hanger' ?
Heres another one to keep the grey cells going. A bracket such as you made to weld to the axle casing holding one end of a shock absorber the other end of which fix's onto a chassis bracket, so the damper is roughly horizontal. (Make it an adjustable & you could 'dial in' the amount of damping in both compression & tension !) Wouldn't have thought you could run with it the whole time (unless you rose joint the shocker ends, and rose joints don't tend to last too long on road cars). After all you are not trying to replace the suspension medium, just trying to take 'shock/violence' out of the axle movement, exactly what a shocker is built to do !
Have fun
Terry
Pallet Puller
Terry
Re: anti-tramp bars
Postby Luke » Sat Apr 11, 2009 9:54 pm
Terry wrote:Hi Luke,
i mean the U bolts :D i think the pivot point is on top of the axle :idea: :D
Re: anti-tramp bars
Postby BROWNYS V6 » Wed Oct 19, 2011 9:40 pm
been makin some new ones :) pre welded pics :wink:
BROWNYS V6
Re: anti-tramp bars
Postby AlanN » Thu Oct 20, 2011 7:38 am
Now they really look the part
Re: anti-tramp bars
Postby Luke » Thu Oct 20, 2011 6:55 pm
nice 8) but why 4 :?: are these for 2 vans or are you 4 linking one :?:
Re: anti-tramp bars
Postby BROWNYS V6 » Thu Oct 20, 2011 9:04 pm
Luke wrote:nice 8) but why 4 :?: are these for 2 vans or are you 4 linking one :?:
yes these are for 2 vans, 1 pair for the mk3, a pair for jono :wink: and yes i am 4 linking the other one aswell :wink: well 5 wiv the panard rod :)
BROWNYS V6
Re: anti-tramp bars
Postby Luke » Sun Oct 23, 2011 8:20 pm
BROWNYS V6 wrote:and yes i am 4 linking the other one aswell :wink: well 5 wiv the panard rod :)
does that mean your losing the leaf springs :?: :D
Re: anti-tramp bars
Postby BROWNYS V6 » Sun Oct 23, 2011 10:26 pm
yeas :wink: coilovers or air :) undecided at the mo :D
BROWNYS V6
Re: anti-tramp bars
Postby Luke » Tue Jun 19, 2012 11:25 pm
just bumping this thread up :D i think a few people at north weald 2012 .....dieselhead123....... fordboynick........... need to have a browse of this thread :D
