colour coding?
colour coding?
Postby trublustu » Fri May 25, 2012 8:23 pm
Hi all :-P
I intend to do some colour coding on my mirrors & bumpers.
Any tips on how to achieve a nice finish, I don't fancy the bag-of-crap look!
trublustu
Re: colour coding?
Postby Vandalism » Thu May 31, 2012 2:18 pm
ive recently respreyed my escort rs turbo bodykit and i just sanded it down with an electric sander, primered it, sparyed it black, then laquered it
7 coats of paint and the same of laquer will give durability :)
Re: colour coding?
Postby transitandy » Wed Jun 13, 2012 11:33 pm
There are numerous threads on painting tips m8y :?: try a search :wink:
Re: colour coding?
Postby trublustu » Mon Aug 20, 2012 11:11 pm
I find the search function on here quite frustrating, can't seem to narrow searches or search single topics and end up with lists of vaguely related stuff.
trublustu
Re: colour coding?
Postby AlanN » Wed Aug 22, 2012 1:32 am
Degrease plastics first, key surface with 400 grit, spray with barrier coat like grip4, if your using cans then use a plastic filler spray, primer out of can is too thin, wet rub down so smooth, you have to do this a few times. Use tack rag get rid of dust etc. spray light layers, you can put a few on then, dont be tempted to load it up, looks great when wet, but soon shrinks back. Once hard, Id give it a week, you can wet rub down with 1200 grit and compound like G3 or t-cut (bl**dy hard work), will look like a mirror 8)
Re: colour coding?
Postby trublustu » Sun Aug 26, 2012 6:04 pm
Top answer AlanN.
Cheers mate... :-)
trublustu
Re: colour coding?
Postby greenmanmark » Fri Mar 15, 2013 8:38 pm
I had a play at colour coding my dash,,, turned out well :D the trick is the prep work........ if you prep it well u will get a wicked finish :twisted:
greenmanmark
Re: colour coding?
Postby trublustu » Fri Mar 15, 2013 9:08 pm
Hi green. nice work, that's pretty funky, different.
I've done a lot of research on plastic, fiberglass and painting over the winter.
Just need things to warm up!!!
I should have some done in time for fordfair/transitmania...
trublustu
Re: colour coding?
Postby greenmanmark » Fri Mar 15, 2013 10:51 pm
plastic primer is a must!
greenmanmark
Re: colour coding?
Postby Vandalism » Sat Mar 16, 2013 12:39 pm
i want to do some colour coding on dads p100 dash but cant work out how to get things like the vent surrounds off with out damaging them, and its a soft dash compaired to a transit plastic one :?
