hi ppl currently bought a crew cab transit twin wheel smiley n reg
MY main objective is to too turn it into a recovery truck for my 205 gti track car n saxo ill be custom making the bed mainly for small cars not too use as a business
the chassey was a tipper body which has been removed it has been lenthed at the rear ill take some pictures next time im working on it
The steel i was gunna use for bed was steel flat plates to bolt to original chassy the weld a lenth off 40mm 40mm 3mm steel to the plates then start doing the uprights for the tilt for bed and use the same steel for cross braces and beavertail the chequer plate the bed
as this is my first atempt at this if any 1 has some advice or pointers to help my it will help loads
problems too solve
weight when beds on
best route for bed
how long too go with bed
tilt on bed
making legal road worthy
any pics off crew cabs will help
