24v cosworth throttle cable
Postby Boffin » Sat Apr 27, 2013 1:21 pm
Hi there, just putting the 24v cosworth engine in my mk2 transit, just wondered what throttle cable those of you have done it are using? i don't have a cable at the mo, just wondered if a cable goes straight on, if not i'll have to modify something. thanks Ben.
Boffin
Re: 24v cosworth throttle cable
Postby Luke » Sun Apr 28, 2013 10:27 am
i used the granada cable and modified the transit pedal by welding the granada end onto it :D
Postby trigger » Sun Apr 28, 2013 9:50 pm
Mk2 Granada injection cable goes straight on the throttle end, not sure about the pedal end on a mk2 Transit tho
Mk5 Transit the daddy
trigger
Postby Boffin » Thu May 02, 2013 5:39 pm
Thanks Lads, tried to get a granada cosworth cable at a ford dealer, they said no we can't get them anymore :( its a 1991 car :? anyway i will try and get a mk2 granada injection cable, do you know roughly how long the mk2 granada cable is? thanks trigger. i'll keep you posted, is there a granada owner's club that does spare's? Thanks again,Ben.
Boffin
Postby trigger » Thu May 02, 2013 10:13 pm
Mk2 Granada injection cable is longer than the carb cable not sure on length tho, carb cable i think has a different fitting on the engine end, try the banger boys as they take all the injection stuff off and fit carbs instead anyway or have a look on ebay
trigger
Postby Luke » Thu May 02, 2013 10:40 pm
the cossy cable is quite long it goes in an S shape so its in line with the cruise control - i'm pritty sure a shorter cable would be ok :D
