Mk7 nudge bar fitting?
Postby AlexHerts » Sat Dec 21, 2013 4:56 pm
Toying with the idea of fitting a nudge bar onto my mk7, but it looks like you have to screw into the bumper either side of the number plate according to the photos I've seen..
Trouble is, I have no holes next to my plate on the front bumper, do you just drill them in and there are holes behind???
Cheers :)
AlexHerts
Re: Mk7 nudge bar fitting?
Postby AlexHerts » Sat Dec 21, 2013 5:02 pm
This is my van/bumper...
AlexHerts
Postby ake » Sat Dec 21, 2013 10:47 pm
What age is your van? Not allowed to fit them to anything after 2007/8 if I remember correctly
Postby Eggski » Sat Dec 21, 2013 10:52 pm
I think that only counts to full wrap around bars.
Custom Trend 2.2 125/290s 64reg (2014) DCIV. (Remapped by Vantuner)
Mk7 2.4 115T350, 57reg (2008) crewcab tipper in Saffron yellow. (De EGR'd and tweeked by Vantuner)
Mk5 2.5 banana, 76ps, V reg (2000) 190 crewcab tipper. (sold but not forgotten)
Eggski
Postby AlexHerts » Sat Dec 21, 2013 10:57 pm
2008. Any ideas about the bumper then??
AlexHerts
Postby little mick » Sun Dec 22, 2013 11:18 pm
Behind your number plate there should be some holes I believe that holds your bumper in place that is what supports the a bar as well mate
little mick
Postby AlexHerts » Mon Dec 23, 2013 8:29 am
Behind the number plate?? Surely you dont have to take the plate off. Does anybody here actually have onenfited??
AlexHerts
Postby ake » Mon Dec 23, 2013 7:49 pm
AlexHerts wrote:Behind the number plate?? Surely you dont have to take the plate off. Does anybody here actually have onenfited??
How hard is it to take out two screws :?:
Postby AlexHerts » Mon Dec 23, 2013 8:03 pm
Not that hard I wouldnt of thought.
AlexHerts
Postby mickmk7 » Tue Dec 24, 2013 12:17 am
If I remember right on mine the brackets go behind the number plate in the original holes that hold the front bumper on then some brackets go under van and attach to back of the little steps at bottom of bumper in total 4 brackets really easy
mickmk7
Postby paulrichardson » Wed Feb 12, 2014 10:23 pm
Hi guys,
Here is a photo of the A Bar fitted to my MK7:-
As you can see there are two brackets which fasten to two existing bolt holes which are behind the front number plate.
Just remove the number plate to expose them.
Mine also has two brackets underneath the van, again using existing bolt holes.
Hope this helps.
Regards,
Paul
paulrichardson
Postby Marty85 » Wed May 21, 2014 8:58 pm
Hi Alex that's the same bar as i have, it is a bit of a pain to fit. You have to drill the bumper to fit it, biggest problem i had was when the holes are drilled there is a metal plate about 2 inches behind the bumper and the nuts fit inbetween the 2. I had to unscrew the top of the grill and squeeze my had down into the gap to screw on the nuts. After alot of swearing and searching the shed for new bolts to replace the dropped ones the job was done.
Marty85
