Transit Custom mods and 'upgrades'.
Re: Custom mods and 'upgrades'.
Postby Mike » Mon Dec 14, 2015 12:32 pm
mavericktc wrote:What is your long time report on these Mike?
Is the warm-up time any problem?
How hot does the glass get? Same as with the original bulbs?
TBH the only time I think about them is when I'm in a car without hids. The warm up time if a fraction slower than the latest hids fitted to Audi, BMW etc but it'd never be a problem. The lenses don't get hot, even if the lights are on and the van is stationary for any amount of time. All in all a worthwhile mod. I'd advise getting them checked at an MOT place for alignment, even though mine didn't need any adjustment.
Mike
Wind up merchant!
Postby mavericktc » Mon Dec 14, 2015 3:35 pm
Does the lens get warm at all?
One positive side affect of the regular bulbs is keeping ice of the lenses.
I have hid on my enduro and from what I remember they get hot too (but they can't handle to much heat).
mavericktc
Postby Mike » Mon Dec 14, 2015 3:39 pm
mavericktc wrote:Does the lens det warm at all?
No, the frost stays on them for a few mins if it's really cold, so no there's hardly any heat.
Mike
Wind up merchant!
Postby poolie » Sat Apr 02, 2016 12:56 pm
Mike wrote:Yellow drl problem solved!
How did you do this mod mike? I have led bulbs fitted in my fog lights from hids4u.
Transit custom limited LWB 130 ps white 66 Plate euro 6
Mercedes E Class AMG Line Black 16 Plate
poolie
Postby Mike » Sat Apr 02, 2016 5:33 pm
Mike
Wind up merchant!
Postby Dave17355 » Thu Feb 02, 2017 11:52 pm
Mike wrote:Plans.
HID upgrade to make the most of the projector lights.
LED bulb upgrades, brake/tail, indicators, interior (cab), number plate light.
Stereo upgrade keeping the factory head unit, so adding a Audison Bit Ten, 5 channel amp, largest mids that will fit in the doors, replacement tweeters in the A pillars, 10" sub.
More to follow :)
Hi Mike did you do the Stereo?
Dave17355
Postby Mike » Fri Feb 03, 2017 8:28 am
Hi Dave, I did the speakers but not the amps and x-over, others have done though and one that I heard recently sounded very good.
Mike
Wind up merchant!
Postby loot » Fri Feb 03, 2017 11:29 am
As good as this?
https://youtu.be/0AfkJoUdDHs
No amps no x over's no chance :lol:
Ids map here
https://uk.virginmoneygiving.com/fundra ... Id=914018#
loot
Postby Mike » Fri Feb 03, 2017 12:09 pm
loot wrote:As good as this?
Yep, much less distortion, good midrange and it didn't make my ears bleed :D
Mike
Wind up merchant!
Postby loot » Fri Feb 03, 2017 1:00 pm
Ah the 90s :lol:
Ids map here
loot
Postby Dave17355 » Sat Feb 11, 2017 10:57 am
I got a Rainbow sub fitted this week,takes the bass away from the speakers and soundsso much better Image
Dave17355
Postby fera » Sat Apr 08, 2017 6:08 pm
Which seems to take a full range feed from the head unit and filter out the lower frequencies with a capacitor.
Hi folks,
I wan't to upgrade my front speakers by a Hertz compo set, in 16,5 cm.
I can replace the mid and tweeters without a problem, dynamax it etc...
But where to place my new hertz crossover ? Where is the Ford one ? The wires are split somewhere but where ?
Can somebody help me please ?
Sorry for my poor English, i'm from Belgium ; -)
fera
Postby fera » Sat Apr 08, 2017 6:09 pm
I'm talking about a Ford transit custom ; -)
fera
Postby fera » Mon Apr 10, 2017 1:17 am
Mike wrote:Speaker wire colours from the rear of the cd player,
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Violet
Right Front Speaker Negative Wire (-): White/Orange
At the speaker end they're marked with paint, the LHS is marked with green (LF +) and yellow (LF -)
Hi folks,
But where to place my new hertz crossover ? Where is the Ford one ? The wires are split somewhere but where ? I mean where to take my inputs for my crossover ? How are the Ford speaker wires wired ?
fera
Postby Mike » Mon Apr 10, 2017 7:55 am
fera wrote:But where to place my new hertz crossover ? Where is the Ford one ? The wires are split somewhere but where ? I mean where to take my inputs for my crossover ? How are the Ford speaker wires wired ?
Put the x-over under the passenger seat.
There isn't a Ford x-over, just a capacitor on the tweeter.
You need to split the wires behind the headunit, feed the full range signal to the x-over, then feed the bass signal to the door speakers via the original wires, then put a new wire in for the tweeters.
Mike
Wind up merchant!
