Luke wrote:Passed
a few little issues to sort - it won't rev up but i think its an issue with the brake pedal switch - at least i can test drive it around now
fingers crossedmartynx wrote:Luke wrote:Passed
Its common failure on the VAG's of the same vintage as your engine , the brake light even can still work but the switch gives a fault & you get engine malfunction message & bleeps etc in the dash !
according to my drawings it's wired back to the ecu so it must read it but it doesn't seem to have the same effect as the brake onemartynx wrote:Not sure if clutch switch is crucial..I'll unplug the one on my '01 Leon TDI later & see if it does 'owt interesting; )
sort ofandz327 wrote:Have you sussed out clutch noise??
not sure but the flywheel and clutch are all crafter the only thing i think is different is the 1.9 crank is shorter than the 2.0 crank, which is why i had to machine the adapterplate downandz327 wrote:Maybe a adapter plate / belhousing bolt a hair too long catching the flywheel, or pressure plate bolts too long and catching the adapter plate
