Mk6 Transit TD04 conversion
Postby K20DJK » Mon Nov 03, 2014 12:07 am
Has anyone modified there transit to get huge power increases? I've built a custom manifold to fit a Subaru TD04 turbo onto my 2.4tTD RWD LWB MK6 transit. The power increase should be substantial if the injectors and fuel pump can keep up with the amount of fuel that's required. I won't know until November 20th that's when it's booked in for remap at Celtic tuning. I have removed the cat and silencers to give better flow to the exhaust and will put a filter on the turbo intake to have minimum restrictions for air supply. If injectors/fuel pump is a problem does anyone know of any upgrades or bigger injectors for these engines? I'm looking to get 160-200hp and around 300 NM of torque before I stop modifying the engine.
Thanks for your replies in advance
K20DJK
Re: Mk6 Transit TD04 conversion
Postby ake » Sat Nov 08, 2014 7:24 pm
Interesting, keep us posted
Postby oldyellar » Sun Nov 09, 2014 12:55 pm
What ps is your van standard?
oldyellar
