Brains_transit wrote:Sounds and looks good but when does the real work begin chop chop
tony&kasia wrote:Brains_transit wrote:Sounds and looks good but when does the real work begin chop chop
I'm getting the tailgate & the rear panel sorted out next, I have the front end booked in with paul2012 for next month. Also i need some welding done to the rear arches & sills. The rust has got a bit worse as it's been sat there nearly 6 months
Brains_transit wrote:tony&kasia wrote:Brains_transit wrote:Sounds and looks good but when does the real work begin chop chop
Yep rust is such a pain in the ass
tony&kasia wrote:After proper inspection on the rear panel where tailgate closes we have decided we are going to replace the panel
Does anyone know the best place where i can get one from please
Punto443 wrote:Same as the barn doors section, keeper in the same place anyway
Oh yeah I meant to say also, the wiring for the mk7 tailgate is on the opposite side of the mk6 tailgate, just thought I'd mention it as you were after one
paul2012 wrote:tony&kasia wrote:After proper inspection on the rear panel where tailgate closes we have decided we are going to replace the panel
That's the same section I am going to replace on the other member Mk6. I'm currently working on at the moment
viewtopic.php?f=27&t=159475#p1346937
Brains_transit wrote:For the top section I'd guess ford would be reasonable or go to the breakers and drill out the spot welds from a mk7
There is 2 parts lower & upper. Upper panel the door striker is secured to. Both panels are over £300 from Ford
Upper panel Ford Part no F4438867 retail price £179 exc VAT
Lower panel Ford Part no F4395788 retail price £101 exc VAT
Best option is to cut that section out from another mk6, which is what I'm planning to do
