Fitting a tailgate mk7
Postby Punto443 » Sat Apr 11, 2015 12:18 am
Thought I'd start a wee thread about converting my double doors to a single tailgate.
So....... First what you need.
A tailgate, I wanted a solid one, no windows.
Replacement bumper top parts
Hinges for the top
Reinforcement brackets for the hinges to mount to.
The gas struts for lifting the tailgate, and mounting ball ends
New lock keeper mounted on the bottom crossmember
Two wedge pieces fitted lower on the corner posts
You'll need the wiring to suit for the tailgate also.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: Fitting a tailgate mk7
Postby Punto443 » Sat Apr 11, 2015 12:31 am
Ideally if your swapping over, you should really cut out and weld over the top hinge mounts of the old doors. But I'm not doing that, I'm just going to either mount a marker light or ????
The bottom hinge mounts will be covered by the replacement bumper caps.
First the reinforcement.
These have a tab that need to slip in between the roof and top crossmember, these are normally sandwiched between these in the factory.
So, I had to cut through the crossmember and bend it down, that let me slip the bracket in.
Then bend the cut part back up, I'm going to give it a couple of tacks with the welder too.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Punto443 » Sat Apr 11, 2015 12:37 am
Them drill the holes out and I've put a couple of bolts in to hold the plate in place stop the water getting in just now.
Next...
Disconnect the wiring, unbolt the restrictors and remove the doors.
Remove the bottom lock keeper.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Punto443 » Sun Apr 26, 2015 10:40 am
So, striped the doors off
And bolted the new one on
The bottom keeper fitted in the same place as the original and latched correctly :D
Just need a bit of lining up.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Punto443 » Sun Apr 26, 2015 11:08 am
Gas struts fitted and because I got a mk6 tailgate, I had to swap the wiring on to the other side and alter the wiring
I'll have to fit the high level brake light to and swap
The rubber seals
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby karl » Sun Apr 26, 2015 12:46 pm
so what fills the holes were the original doors went ?
karl
Tranny Lover!!!
Postby Rumble bee » Sun Apr 26, 2015 12:49 pm
Gas struts are upside down fella :!:
Or mine are :lol:
Rumble bee
Postby jonny round boy » Sun Apr 26, 2015 12:50 pm
karl mcghee wrote:so what fills the holes were the original doors went ?
Twas in the first post...
Punto443 wrote:Ideally if your swapping over, you should really cut out and weld over the top hinge mounts of the old doors. But I'm not doing that, I'm just going to either mount a marker light or ????
Insert amusing/intelligent/witty comment here
jonny round boy
Postby Punto443 » Sun Apr 26, 2015 1:21 pm
Rumble bee wrote:Gas struts are upside down fella :!:
Or mine are :lol:
:lol: well atleast there easy to swap :D
And I've got the pillar sections to cut out and swap. But I'm thinking I'll find something to mount there rather than cutting out and welding :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby coacher » Mon Apr 27, 2015 12:58 am
Glad to see it's gone to a good home. Now I've got to sell the rest of her.
coacher
Postby Kedishen » Mon Apr 27, 2015 1:46 am
handy with the camera punto. I barely manage to get a before and after whenever I do something. Technology confuses me :o
Livin' in me van in Portugal.
'93 Mk4 TD 150L Hitop Custom Camper
100ps Epic blue spot
Kedishen
Postby Punto443 » Mon Apr 27, 2015 9:29 am
Removed again and stripped to prep for painting :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Punto443 » Mon Apr 27, 2015 11:05 am
And before I forget!
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby KING OF ENGLAND » Mon Apr 27, 2015 9:20 pm
You not been to work then :?:
KING OF ENGLAND
Postby Punto443 » Mon Apr 27, 2015 9:24 pm
Just no had the time to go to work craig :D
To much to do on the van :lol:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
