Can anyone help with some info about MT75 gearbox and clutch
Postby sven » Wed Aug 05, 2015 10:19 pm
Hello all
I have a new project going on,( which strictly isn't ford) where I am looking for a short gearbox I can modify to fit a rover V8 into a Suzuki SJ413
Can anyone confirm that the transits MT 75 gearbox have an 1" inputshaft with 23 splines?
and wasnt a 267mm clutch an option on some of the transits?
And at last I wonder if anyone knows the approximate length of a MT75 gearbox from front of bellhousing to propellershaft
if anyone can help me with this I will be extremely happy
regards
Sven Glosli
sven
Re: Can anyone help with some info about MT75 gearbox and cl
Postby MinorMatt » Thu Aug 06, 2015 10:39 pm
Dieselhead123 does an adaptor plate to mate the rover v8 to a transit mt75 (not DOHC).
Spline size sounds right - but would need to checl
There is a large clutch (its 265mm iirc)
Would need to check the length
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby sven » Thu Aug 06, 2015 11:14 pm
Thank you MinorMatt.
Found the V8 in Transitthread now, and it gave me allmost all the information I needed:)
'I would really appreciate if you could check approximatly how long it is:) so I can see if the rover/transitcombo will fit:)
Thank you :)
sven
Postby MinorMatt » Fri Aug 07, 2015 9:22 am
If no one else has... I will do some measurements next weekend on my loose box?
93 L GL Minibus
