transit mk3-5 four link suspension ???
Postby mike En » Sun Sep 18, 2016 9:00 pm
As above, just throwing an idea out there, I know you can buy kits to convert early escorts/capris etc from leaf springs to four link setup with coilovers. Just wondered if its been done on a transit ?
I like the idea of doing away with the leaf spring and fitting regular shock and spring. Or even better would be running airbag setup :)
mike En
Re: transit mk3-5 four link suspension ???
Postby LengTimes » Wed Sep 21, 2016 6:12 pm
did you go ahead with it? I'm planning on getting a transit connect, removing the leaf springs and putting it on bags. :D
LengTimes
Postby mike En » Wed Sep 21, 2016 7:59 pm
No, purely just throwing an idea out there !
If I was more confidant at welding and had the time and spare money id have a crack at it though !
mike En
Postby Luke » Wed Sep 21, 2016 8:51 pm
i thought about it but decided it was too much hassle and the van was never going out out handle a ferrari so in the end i kept the leaf springs but fitted anti tramp bars :D
for airbags it could work tho :idea:
Postby Luke » Wed Sep 21, 2016 8:54 pm
this is mine (painted now tho) :D
Postby Buzzer » Thu Sep 22, 2016 5:45 pm
I've looked in to this aswell. But on a FWD mk6. And like said, if you want to run air bags it could be ideal..
The other option i have thought about would be to five link it and then rather than run airbags, mount it on coilovers.cheaper way of getting it to sit low :wink:
Buzzer
