Winding up mk5 front end
Postby jaanos » Thu Nov 03, 2016 1:02 am
Hi guys, I've searched for this to no avail so wanted to ask if it's possible to wind the front end of my 98 mk5 transit up an inch or so to match the rear so it sits more level. This is possible on a hiace and also an old Navara I used to own... Cheers!
jaanos
Re: Winding up mk5 front end
Postby Aardvark » Sat Nov 05, 2016 10:46 am
You want to raise the front? You could always try a spacer somewhere but I would opt for changing the springs for longer ones. There are spring specialists out there that can mod yours or supply new to your specification.
I have always lowered vehicles for the cool look and my HiArse was no exception. I cut one turn out of the front springs and fitted 2 and a half inch lowering blocks and longer u-bolts at the rear. Cornered like it was on rails and ended up low enough to fit into my garage. 8)
Learning to love rust.........
Aardvark
Postby 4x4 tranny » Tue Nov 08, 2016 9:46 am
and ride like a dray?????lol
4x4 tranny
Postby Wadey » Tue Mar 21, 2017 11:34 pm
New springs will probably make a difference the ones you have im assuming have been On there a long time so hane probably sagged with age ??
just follow the onscreen instructions and it's fairly idiot proof...trouble is, we keep producing better idiots
Wadey
Postby trigger » Fri Mar 24, 2017 12:25 am
Just lower the rear to match the front
Mk5 Transit the daddy
trigger
Postby darkbluevanman » Wed Apr 12, 2017 5:36 pm
I put 190 springs on my SWB... which settled down nice over time
darkbluevanman
