Transit atb lsd
Transit atb lsd
Postby rob hall » Mon May 15, 2017 1:41 pm
Just bought this off ebay does anybody else have one ? Do they work well? Its currently gear 5.14
Isit possible to change the cwp for a lower ratio , i.e more top speed?
Came off a mk5 twin wheel
the welsh A-team!
rob hall
Re: Transit atb lsd
Postby rob hall » Mon May 15, 2017 1:45 pm
[img]
the welsh A-team!
rob hall
Re: Transit atb lsd
Postby rob hall » Mon May 15, 2017 1:46 pm
Lsd
the welsh A-team!
rob hall
Re: Transit atb lsd
Postby Mfr » Thu Jun 01, 2017 4:06 pm
Hello, yes I have the same on on mine, I love it, you can swap the cw&p to a 4.63. That's what I did, got a gearbox rebuilder to do it for £225 with new bearings but I supplied the cw&p. Make sure you use LSD oil only!! I use Castrol B373, it has the additives already in so just get 2 bottles and fill it up.
Mfr
Re: Transit atb lsd
Postby MinorMatt » Tue Jun 13, 2017 3:07 pm
I agreed a price for it with him, and then he decided he wanted more... so I left it and bought the one that was for sale here.
Quaife ATB type don't need LSD oil, ordinary diff oil is fine.
My LWB 150 has a quaife, the SWB is getting the plate type. Traction on slippery surfaces is much improved, and drifting is much easier
96 N 120 Turbo'd DI SWB Low
96 P 150 TD (100PS EPIC) LWB Hi-Top
97 P 150 76PS Di SWB low ex essex police
Lucas laser 2000 & IDS onwner
Gaffa tape is like the force - it has a light side, a dark side, and it holds the universe together.
Re: Transit atb lsd
Postby bj928 » Mon Jul 10, 2017 4:36 am
i'm going to be working on a full IRS on my van over the winter, the new mustang 2015> have a lovely sub-frame like the old jag irs, but lower slung, and just 4 bolts and its in, should be perfect for width as well, comes complete with everything fitted to sub-frame, will do away with the springs and go with coil overs, maybe need to fit escort mk1 shock towers
bj928
