Mk2 transit with two overdrives
Postby mk2 van man » Sat Mar 03, 2018 5:33 pm
Here are some pictures of my progress so farImage
mk2 van man
Re: Mk2 transit with two overdrives
Postby Luke » Sat Mar 03, 2018 7:47 pm
interesting :D
Postby Phatiphatn12 » Tue Apr 17, 2018 8:31 am
I was interested in Mk2 transit with two overdrives.
Phatiphatn12
Postby Catjenkins » Tue May 29, 2018 3:06 pm
How far back did you mount the 2nd unit? I have a separate o/d unit I want to fit to my mk5.
Catjenkins
Postby bambi mk 1 » Thu May 31, 2018 10:21 pm
Wonder what happened when you tried to reverse it :?: Was it boom and crunch :?:
Theres the good guys,theres the bad guys but there only ever be one SPEED GUY
bambi mk 1
Postby Catjenkins » Fri Jun 01, 2018 2:57 pm
Turn it off
Catjenkins
Postby vanfox » Sun Jun 03, 2018 9:20 am
I have a "J" type O/D fitted after the MT75 box. It's U/Jd directly onto the MT 75 output flange, stops it shakin' about. It has a short shaft attached to the output flange which sits in the centre bearing carrier.
Works well, gives 29mph per 1000 rpm. Will easily pull 3000rpm if I dared try. Bosch TDi motor. 4.1 diff......
I guess this guy has a 4 speed + overdrive box. Same principal should work, depending on the output shaft from the "front" O/D. Wire in the O/D defeat switch to both to save trying to reverse in O/D, it don't like it. Take speedo drive from the second unit.
vanfox
