Breakdown Biker wrote:Btw, can you recommend a filler for the plastic grill
I've finally managed to get the materials together to mod the grill
but don't know what filler to use on the joins
Thanks for the advice and the link.
The best stuff I have found, is "Isopon bumperfil", it bonds to most plastics unlike ordinary body filler. Comes in a tube, a bit expensive, but works OK. One thing I would recommend, is to reinforce the back to stop flexing. Plumbers glue will weld the plastic and glue the reinforcing. Remember to use some plastic primer, stops it peeling long term
