Little bit more progress on the arches today , Managed to fit both rears and started cutting the front N/s to allow door to open.
Only problem i've had is the windscreen sealer I used hasn't bonded to the plastic arch so its back to the drawing board(any suggestions welcome.
there is a small section that is tobe fitted to the door and the space between is to be filled.
As you can see from the last picture I have cut the arche to allow original bumper to fit underneath. They are not totally central but I can live with it...
Just need to work out how to space the sliding door to clear the new arche
As can be seen in a previous post I managed to mark out and drill the rear panel to alow the use of the original body clips. this worked so well that I couldn't get the bugger offf earlier.
