My mk6-7 Front End Conversion photo album
Re: My mk6-7 Conversion photo album
Postby stephenferguson » Thu Nov 01, 2012 6:45 pm
hi hillman.
1, Use a mk7 transit as a guide for the measuring. There are some factory drilled holes in the side of the chassis which are in the same location on a mk6, you can use these holes to measure off. It is very little what is cut off from what i can remember.
2, Back in the thread i have tried to explain about the indicator mod, its the best way i can describe it mate.
3, My transit was already electric, so the doors were the same but you need to use the mk6 door loom as it affects the central locking. And you will need a double window switch off a fiesta as the mk7 transit window switch only has one plug.
Hope it helps and good luck!
2008, VW Transporter T5, T30, 6 Speed 130, Reflex Silver.
2006, 100 T280, MWB, Mid Roof, Moondust Silver. SOLD
Mk6-Mk7 Facelift Photos Here
stephenferguson
Postby hillman » Thu Nov 01, 2012 11:37 pm
hi stephen
thanks for your reply
the mk7 doors i have the drivers side one has a double switch so do you think this will be ok or do i still need to swap the wiring looms over.
hillman
hillman
Postby stephenferguson » Thu Nov 01, 2012 11:46 pm
Use your existing looms, because when using the mk7 looms, when you lock the doors they just reopen.
If your van hasnt got leccy windows to start anyway, u are going to have to wire them up seperate anyway, you will still need a window switch with two plugs on as well i think. But the seperate window wiring im unsure of.
stephenferguson
Postby hillman » Fri Nov 02, 2012 11:45 pm
stephenferguson wrote:Use your existing looms, because when using the mk7 looms, when you lock the doors they just reopen.
hi stephen
thanks for your reply and advice, i'll see what we can come up with and if we get it sorted i'll let you know.
regards
hillman
hillman
Postby jolly olly » Tue Dec 11, 2012 11:25 pm
Spotted you again this morning again, you were turning left just before the red lion pub.
What bulbs are you using as it looked really smart and not the usual mish mash cheers.
Life is not a dress rehearsal
jolly olly
Postby stephenferguson » Wed Dec 12, 2012 12:29 am
Did you go past me in the red 61 plate? Cant remember if you said ures was red. It will have been the drls that were on, they are the led com ones. I do have smd led sidelight lamps, hid headlight lamps and led marker lamps as numberplate lights. Oh and very bright smd reverse lamps.
stephenferguson
Postby jolly olly » Wed Dec 12, 2012 12:43 am
Red 60 plate, passed you just as you were on the slip road turning off, I will blip the horn next time.
jolly olly
Postby stephenferguson » Wed Dec 12, 2012 12:48 am
Yes i seen you passing me, aye honk the horn, i'll probs still be wondering who it is lol
stephenferguson
Postby jolly olly » Wed Dec 12, 2012 12:50 am
I clocked your awning first as I was 2 cars behind you.
jolly olly
Postby stephenferguson » Wed Dec 12, 2012 1:04 am
Hopefully the whole van will be that colour one day!!
stephenferguson
Postby karl_oms22 » Mon Jan 28, 2013 8:47 pm
iv done mine today its well worth doing but just remember to measure align and test fit 10 times and weld the once, if any body is wondering about how much to cut of chassis legs I just cut mine directly infront of the rad support bar I think its about a inch and its a really nice fit with the bumper -its a bit harder to cut on the passenger leg as there triple skinned as theres a towing eye on that side,you can either buy the ford bits or just make a panel up I used the old bit I cut off and bent the old edges inwards and fitted them inside the chassis leg and welded all round then made 4 new holes for the impact bar - you will need to weld another plate at the top for the slam panel (crossmember) brackets just remember to elongate the holes so if you need to you can adjust the position and then just bolt it up,im going to have to use some self tapping screws on my scuttle trim as old flitch covers the mounting points, just need to sort the headlight wires and a few other odds and ends.
if any one has any detailed info and pics about the wiring for headlight it would be greatly appreciated, aslo iv got some mk7 doors with electric windows if anyone now how to get them working as I hear theres a issue with the central locking my van has manual window wipers.
karl_oms22
Postby priesty » Tue May 14, 2013 7:34 pm
Got mine on today thanks to this post the headlight wires only took 10 mins the hardest part was removing the wiper nuts :shock: rusted on solid didn't expect something daft to hold me up
so we have a blue one with a red front kicking about durham aswell :lol:
priesty
Postby jolly olly » Tue May 14, 2013 10:31 pm
I clocked you again this morning just as you passed me just after the petrol station between Stanley and Beamish about 750.
jolly olly
Postby stephenferguson » Tue May 14, 2013 10:38 pm
Haha preisty another liquorice all sorts on the roads!
Would have been Droppin the bairns off jolly
stephenferguson
Postby ossie cossie » Wed Oct 16, 2013 7:01 am
good thread i will be doing mine soon will be back when i do to ask questions as i go along.
ossie cossie
