by hughesyn » Tue Jul 31, 2018 7:55 am
Get slam locks or dead locks fitted to the side and rear doors and a rep lock for the drivers door.
Go to an expert, they should also install a little metal plate on the sliding door.
Slam locks disconnect the handle mechanism and replace it with a key. This means if the drivers door is unlocked with a pick, and the central locking unlocks all doors, the doors still need a key to open.
Dead locks just add an extra lock on the door for the same reason, you just have to remember to lock it.
They can help peel and steal if fitted high up.
Drivers door rep lock is because the pick device is easily available and lots of tea leaves have them.
It'll cost a few hundred quid, but without them you might as well leave the doors unlocked.
Van vault is a good idea for smaller expensive stuff.
2023 Mk8 DCIV 170 auto L3H2
