Mk7 Transit interior light / number plate sizes ???
Postby Geztransit » Sun Jun 24, 2012 6:42 pm
Hi guys , was going to buy led replacements for all my interior lights , front and rear but can't seem to find the sizes of them? Was hoping someone would know , also rear number plate lights if possible!
Please don't think I'm lazy but my van is stored 15miles away from at the moment!
Many thanks for any info in advance!
Geztransit
Re: Mk7 Transit interior light / number plate sizes ???
Postby blue estate » Sun Jun 24, 2012 6:46 pm
load area are 43mm festoon number plate and side light are 501 w5w don't bother with cab lights as they are not wired right for led
blue estate
Postby blue estate » Sun Jun 24, 2012 6:48 pm
I've just put 3 of theses in the load area of my jumbo and it's like a flood lit football pitch now
http://www.ebay.co.uk/itm/250867777655? ... 1497.l2649
blue estate
Postby Geztransit » Sun Jun 24, 2012 7:01 pm
Ok they look good, do they come on when doors are opened , or have to be manually switched on?
Also why won't cab lights works ? I was really looking forward to led cab light! (sad I know!)
Also just to confirm number plate lights are 501's - I.e same as sidelights?!
Geztransit
Postby Mike » Sun Jun 24, 2012 7:08 pm
Geztransit wrote:Ok they look good, do they come on when doors are opened , or have to be manually switched on?
The polarity is wrong for direct replacement cab lights.
Yes number plate and side light are the same but remember that they need to emit the light from the sides to work properly in the number plate position.
Mike
Wind up merchant!
Postby blue estate » Sun Jun 24, 2012 7:20 pm
I have pluged them in to the factory loom spades for now so plug and play :wink: but i will be puting them on thier own curcit of the battery take off point so i can control when they are on and off
blue estate
Postby Geztransit » Sun Jun 24, 2012 8:19 pm
Can't I just turn the bulb round if polarity is wrong ?
Geztransit
Postby blue estate » Sun Jun 24, 2012 8:25 pm
only on the number plate one's the cab one's are bayonet fitting
blue estate
Postby Mike » Sun Jun 24, 2012 8:27 pm
http://www.phoenixautobulbs.co.uk/pr/led-433-quad/
Mike
Wind up merchant!
Postby Geztransit » Sun Jun 24, 2012 8:49 pm
Do these bulbs work for the transit ?!
Geztransit
Postby Mike » Sun Jun 24, 2012 8:50 pm
No, as we said they're the wrong polarity.
Mike
Wind up merchant!
Postby kevsterjw » Wed Nov 28, 2012 3:13 pm
would it cause problems to swap the supply wires round for the cab light fitting?
kevsterjw
Postby blue estate » Wed Nov 28, 2012 6:24 pm
kevsterjw wrote:would it cause problems to swap the supply wires round for the cab light fitting?
Plugs are differant
blue estate
Return to Transit Talk
