Spec lift laws
Spec lift laws
Postby winterheating » Wed May 02, 2012 2:13 pm
Is there any reason why you couldn't combine A spec lift idea with a recovery body??
So the front wheels onto a beaver tail and dropped into an opening like on a spec lift?
Does a spec lift articulate normally? Or is it fixed ?
Also how can they be in use without having the towed vehicle braked???
Basically thinking of a scenario where you have a recovery truck that is able to take the weight but not the length of the broken vehicle.......
winterheating
Re: Spec lift laws
Postby jay » Wed May 02, 2012 3:46 pm
you will find a lot of 7.5t upwards recovery/tilt and slide usually have a spec lift under the body..spec swivels like transit specs do..
they are in use as recovery only which is why towed car/lorry/van dont need to be braked,bigger specs/underlifts also have a air pipe to supply air to a lorry being towed to keep the brakes off as well.
when you mean length i assume u mean say you go out in a 7.5tonne to pick up a jumbo transit the tranny wont go on the bed as its body hits the ground when trying to load so you put it on the spec lift instead(done that a few times with xlwb sprinters on my old cargo)as long as the spec is able to lift the weight(plated weight on the spec body/arm)its ok
70ps semi high top mk5.
jay
Re: Spec lift laws
Postby Muttley » Wed May 02, 2012 5:54 pm
Be careful with the overhang though :wink:
Expert burns reciever.
Bodger Extraordinaire!!
Old Fords never die, however, mine are on life support!
Happy member of the "MK3 Massive"
Muttley
Re: Spec lift laws
Postby Guy88 » Wed May 02, 2012 10:52 pm
if i read it the way i think i am then your thinking of putting the front onto the bed and support the rear with the spec :?:
if so i doubt you could, the spec wouldnt lift high enough to do it
there articualted when in use and fixed when not, normally they unlock automatically
also generally dont see many beavertails with a spec on it as the approach angle is so high most cars catch
slidebed is the way to go, if it dont fit on then spec it :wink:
also an easy way of recovering heavier vehicles (too heavy for GVW but light enough for the GTW) and when its say a luton and its windy
2008 200 T350, LWB GLX,
1999 SWB low roof ex BT, officially rotten and awaiting restoration
LIVIN' LOUD
Guy88
Re: Spec lift laws
Postby jay » Thu May 03, 2012 6:58 am
I have fond memorys and tight arse cheeks when i had a luton van on the back of a 71.5tonnne slide bed with another on the spec and going over orwell bridge in high winds..
jay
Re: Spec lift laws
Postby 125neil » Mon May 07, 2012 3:17 pm
If I read it correctly do you mean having the front of the vehicle on the back of the truck and the rear wheels on the ground and rolling? If so there is such a truck operating around the Birmingham area, I have not been close enough to see how it works but basically last time I saw it there was a Van on the beavertail with its front wheels just behind the back axle, its rear wheels were on the ground. It was swb relay/boxer van being towed and the towing vehicle is a 3.5 tonne beavertail. I can only assume that the beavertail part of the transporter swivels somehow for it to work.
125neil
Re: Spec lift laws
Postby Muttley » Tue May 08, 2012 7:09 pm
If they strapped the front wheels to the bed and kept the winch cable on it then the steering would allow it to turn. Totally illegal though :roll:
Muttley
Re: Spec lift laws
Postby winterheating » Tue May 08, 2012 7:17 pm
Yeah I meant to just put front wheels on the back of beaver and rear wheels on the ground.
How much would it have to twist to be right, as much as a trailer?
Is there a minimum measurement overall of the 2 vehicles before it needs to pivot?
winterheating
Re: Spec lift laws
Postby Muttley » Tue May 08, 2012 7:18 pm
winterheating wrote:Yeah I meant to just put front wheels on the back of beaver and rear wheels on the ground.
As I say above, totally illegal, you would be done for an insecure load :roll:
Muttley
Re: Spec lift laws
Postby winterheating » Tue May 08, 2012 7:21 pm
Muttley wrote:If they strapped the front wheels to the bed and kept the winch cable on it then the steering would allow it to turn. Totally illegal though :roll:
Be good if front wheels could be strapped correctly and a steering setup fixed legally....
winterheating
Re: Spec lift laws
Postby winterheating » Tue May 08, 2012 7:23 pm
So what exactly makes a spec lift legal then...
winterheating
Re: Spec lift laws
Postby Muttley » Tue May 08, 2012 7:25 pm
No, it could never be legal. Your load must be supported fully by the body if its a beavertail. Half of it hanging off the back will never do :wink: A spec lift is designed for lift and tow of disabled vehicles.
Muttley
Re: Spec lift laws
Postby winterheating » Tue May 08, 2012 7:33 pm
So something like this could never be incorporated with a beaver tail.
http://www.youtube.com/watch?v=V9XVA2rv ... ata_player
winterheating
Re: Spec lift laws
Postby Muttley » Tue May 08, 2012 7:41 pm
Yopu could feasably fit a spec under the back of a beaver. Problem is that the tail of the body would be too low for the frame to fit. You would also not be able to lift high enuff to tow :wink: Thats a Century repo truck and that guy has done that before, top lift and tow all under a minute, class!
Muttley
Re: Spec lift laws
Postby winterheating » Tue May 08, 2012 8:01 pm
I've watched this 3 times and can't see how the hell it works....
http://www.youtube.com/watch?v=rjKWeegq ... ata_player
winterheating
Return to Transit Talk
