mk5 transit glow plugs or not? ecu or not?
Postby jay » Tue Jun 19, 2012 3:08 pm
right had a little argument at work last night with someone well more banter really..
he says my mk5 must have glow plugs and electric injectors and a ecu which controls the engine and all electrics....prove him wrong peeps.
btw I know I am right as been on transits for years
pic of my van A swb semi high 2.5Di
oh keep it clean as I will be showing him this thread..
70ps semi high top mk5.
jay
Re: mk5 transit glow plugs or not? ecu or not?
Postby Altransit » Tue Jun 19, 2012 3:22 pm
Ford Di engine .................. absolutely NO glow plugs, could have an ECU if it's a Turbo, but definitely NOT electronic injectors :P :D
1997 Mk5 SWB 115 Minibus 70ps Di
2004 Mk6 SWB T280 Medium Roof 85PS TDDi - Vantunered
Postby jay » Tue Jun 19, 2012 3:43 pm
My van is non turbo..
jay
Postby Altransit » Tue Jun 19, 2012 3:45 pm
jay wrote:My van is non turbo..
Just pointing out the options ..... :wink:
Postby KevAmiga » Tue Jun 19, 2012 4:06 pm
Deffo no glow plugs.
- 1999 ex BT mk5 SWB 2.5di - CB - DAB - Solar Panel Charger - Kenwood Audio / Amp / 6 x 9's -
KevAmiga
However... if there are no glow plugs, how does it start?
KevAmiga
Postby jay » Tue Jun 19, 2012 5:30 pm
2.5Di is direct injection
only indirect have glow plugs but newer direct injection have them to assist in cold start emmisions.
jay
Postby ake » Tue Jun 19, 2012 5:55 pm
Transit 2.5 Di was never fitted with glow plugs, and should start at - 15 without assistance. The flame start option was fitted to 115ps turbos and some overseas versions.
The fuel system is a mechanical pump and injectors, and if you remove the plunger from the stop solenoid the engine will run without a battery or alternator.
The Di would start with out glow plugs because the compression ratio is so high, modern turbo diesels have a lower compression ratio, and so have glow plugs fitted to reduce emissions and help cold starts.
Everyone is entitled to my opinion
Ford Transit 125ps 260 Trend
Ford Transit 130ps 350 Chausson Flash 03
Postby trasitman » Thu Jun 21, 2012 7:36 pm
Just had this conversation just to find the answer to our questions posted only 2 days ago!¬!
trasitman
Return to Transit Talk
