Cleaning out egr and inlet manifold
Postby Crankshaft » Fri Sep 30, 2016 5:31 pm
Took my egr and inlet manifold off whilst changing the timing solenoid on my mk6 90ps and needless to say they were filthy.
The egr was almost completely blocked and the inlet wasn't as bad but still full of greasy carbon.
I've used solvent degreaser in the past, but had some no nonsense heavy duty degreaser from screwfix from another job, decided to give that a go, amazing results, this stuff eats carbon.
Mixed it way stronger than recommended at 4 parts water to 1 part degreaser, scraped the majority off and poured it in, left to soak for half an hour then poured what looked like black crude oil out. Scraped the stubborn bits with a screwdriver and bottle brush then gave it another soak. Almost like new now.
Egr before
Egr after
Inlet before
Inlet after
Sent from my SM-G850F using Tapatalk
Crankshaft
Re: Cleaning out egr and inlet manifold
Postby ned » Fri Sep 30, 2016 9:36 pm
When do you want to do mine :lol: I believe oven pride works as well. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Crankshaft » Sat Oct 01, 2016 12:13 am
Crankshaft
Postby chris72a » Sat Oct 01, 2016 12:47 am
Good job and Pics, I am waiting on a set of new inlet manifold seals so I can do mine, not looking forward to it.
Chris.
chris72a
Postby wicklabilly » Sat Jun 10, 2017 4:36 pm
[quote="Crankshaft"]
Hello there Crankshaft,
I too have undertaken this dirty task and got the EGR, Inlet manifold, and the intercooler and both it's hoses totally clean and crud free. Now tell me this esteemed Transit experts, I am going to blank the EGR off but do I reconnect both the sensor plugs? Also in the pic below is it possible to cut that pin out as it's essentially a restriction innit? Thanks in advance.
Egr after
2002 Yella Transit Crew cab Tipper. T350 120 bhp Fairly clean and literally no chassis rust. 2011 MK7 crew cab Transit tipper. T350 115PS Euro 4
wicklabilly
Postby Dodge20 » Sun Jun 11, 2017 6:25 am
Egr after
That 'pin' you see is the butterfly valve edge on, if you're going to blank it off what's the point in hacking the valve out?. Reconnect the plugs the pcm needs to see the valve moving.
Some people are like slinkies.... not good for much but bring a smile to your face when you push them downstairs.
2009 280 85hp
2015 290 Custom DCIV twin side doors 155hp(tragically killed)
Dodge20
Location: Go to the end of the world and turn left. (South Cumbria)
Postby PaudieG60 » Sun Jun 11, 2017 8:16 am
Im thinking of doing the same to my own van.
Apart from a new inlet gasket, is there any other parts i should get just incase anything gets damaged or broken?
PaudieG60
Postby wicklabilly » Sun Jun 11, 2017 11:22 am
PaudieG60 wrote:Im thinking of doing the same to my own van.
Don't tink so Paudie, buy Gunk degreaser and Mr. Muscle oven cleaner and keep scraping away at what you can see, I kept soaking the affected parts in degreaser ferra few hours then flushed them out with the garden hose, then back into the degreaser, so on and so forth. I inspected the inside of the intercooler and inlet manifold with a bore scope and it's **MINT** inside and out now. I also removed the old clogged up pollen filter and binned it and i'm not going to replace it. It's all a time consuming task I can tell ya!
wicklabilly
Postby PaudieG60 » Sun Jun 11, 2017 11:25 am
Thanks for the advice!
Its a job ive had on my list for a good while now so just want to have everything before i strip her.
Is yours fwd or rwd?
Mines rwd so hopefully I'll have easy access to everything
PaudieG60
Postby wicklabilly » Mon Jun 12, 2017 2:21 am
PaudieG60 wrote:Thanks for the advice!
How ya, mine is a (dual) rear wheel drive crew cab tipper 2.4. It's fun trying to access the inlet manifold bolts! I removed the wipers, scuttle panel, trim etc, then removed the EGR and the pollen filter housing to make access to the aforementioned bolts easier. Really go to town on cleaning out the crud from the EGR and the inlet manifold is my advice. I also blanked off my EGR while I was in there.
wicklabilly
Postby PaudieG60 » Mon Jun 12, 2017 6:15 am
Im a 2.4 rwd aswell so that's good to know!
Any pics of the egr blanked?
Its on my list aswell, just not 100% on what to do with it
PaudieG60
Postby wicklabilly » Thu Jun 15, 2017 11:55 am
PaudieG60 wrote:Im a 2.4 rwd aswell so that's good to know!
Paudie, simply identify which type of EGR ya have by looking at the pics on the ebay sellers page. Fitting takes about 1 minute (in my case) as all ya gotta do is slacken off 2 bolts, slide in the blanking plate, retighten the 2 bolts, drink tea and eat cake. Very very very easy to do.
wicklabilly
Postby Remix » Sun Aug 06, 2017 8:27 pm
Good job man, you've motivated me to do mine....did it make much of a difference to the running of the vehicle?
Cheers fella
..:: 2004 MK6 85ps T280 SWB Low Roof 2.0 TDDi ::..
Remix
Postby trannyfreak » Sun May 30, 2021 2:09 pm
How do you clean out the inlet pots on the head where the inlet bolts on to? Many thanks
trannyfreak
Postby wicklabilly » Sun Jun 13, 2021 9:26 am
trannyfreak wrote:How do you clean out the inlet pots on the head where the inlet bolts on to? Many thanks
that i wondered too as i was concerned that crud may fall into the combustion chamber :!:
wicklabilly
Return to Transit Talk
