Pros / Cons Single or Twin Battery Mk7
Postby Rubz » Tue Jan 24, 2017 1:49 pm
Afternoon all,
What are the pros and cons of a twin battery over a single?
My mk7 2.2 fwd has a single battery but seen a few people convert to a twin.
Just looking to see if its worth the time/ money / effort of adding a second battery.
cheers all,
Euan
2011 Audi A3 Black Edition 170PS Quattro
2009 Ford Transit 115Ps T300M MWB Ex British Gas
2004 Ford Transit T280 SWB - SOLD
2014 Honda CRF250R Muscle Milk
Rubz
Re: Pros / Cons Single or Twin Battery Mk7
Postby loot » Tue Jan 24, 2017 5:25 pm
Punto has the stuff you need it's in the sale section.
The main and overall bonus to twin battery setup is that, provided you maintain 2 good batteries you'll never go flat by accident.
Imagine if you went to do a bank raid and you left the lights on :idea: that could be embarrassing, especially when you have to explain to the wife and kids that you, Charlie and knuckles are doing a stretch in the klink :cry:
The above scenario generally can't happen on twin battery system.
Down side is that when the front battery dies, you have to rely on your Jedi powers to spot it, usually tell tale faults occur tho. :-)
07 350 170ps
Ids map here
loot
Postby boltondigger » Tue Jan 24, 2017 6:08 pm
Good set of jump leads left in the back ,scrounge a jump if you ever need it.
And save yourself approx £100 .
Had a rusty old 58 plate 85 ps swb.180 thou .most reliable bus ive ever had
12 plate limited 125bhp 260 that got nicked :shock: :shock:
2016 connect poverty spec
boltondigger
Postby ake » Tue Jan 24, 2017 6:44 pm
If you frequently use things powered from the van with engine off, it's worth it.
If you don't, then it's up to you, but I reckon it's still worth it!
Postby Altransit » Tue Jan 24, 2017 7:09 pm
Some folk have been known to leave dash cams plugged in :oops: , and even Chinese USB sockets, which can flatten the battery after a few days of not using the van :(
Having a separate starter battery, isolated from the rest of the system is ideal for such folk, and you have the added bonus of additional starting amps in cold weather 8)
Postby Rubz » Thu Jan 26, 2017 8:22 am
cheers for your thoughts guys. Ive bought the twin battery set up from punto.
for buying a second battery, should I get the exact same one I have currently? or a smaller capacity battery?
Rubz
Postby gotgcoalman » Thu Jan 26, 2017 7:33 pm
Haven't got a mk 7 but from what iv'e read in the past and what i'd put on
my mk5 is a matched pair. :D
Too bloody quiet :shock:
gotgcoalman
Postby Altransit » Thu Jan 26, 2017 8:57 pm
Ideally, the same size and capacity, but as they're not connected together when discharging, it's not essential.
I wouldn't use a smaller one than the original, as it may need to start the van on it's own if the other battery is flattened or goes faulty :wink:
Postby Rubz » Fri Jan 27, 2017 8:28 am
10-4 roger that i was thinking that would be the anwser.
Rubz
Return to Transit Talk
