Van Security
Van Security
Postby Gloria » Mon Jul 30, 2018 10:27 am
I have just bought a Mk 7 to replace a Vito for my gardening business. I do have to leave some of the bigger tools in the van over night so I am a little concerned about the van's security. Is it worth fitting extra locks, I often see vans with additional locks on the loading doors, do these work? how easy are they to fit, are these a good option? https://www.screwfix.com/p/master-lock- ... 30mm/3866d
Gloria
Sic transit Gloria mundi
Gloria
Re: Van Security
Postby MinorMatt » Mon Jul 30, 2018 4:22 pm
Look up peel and steal...
Van vault?
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Re: Van Security
Postby gotgcoalman » Mon Jul 30, 2018 11:10 pm
As Matt says.
Even if the door has a robust lock in the middle the tops are a weak point.
fabricating an internal cage might be an idea.
Been looking for the bjt cage build.
24000 posts to wade through :shock:
Too bloody quiet :shock:
gotgcoalman
Re: Van Security
Postby bigjohnthomas » Tue Jul 31, 2018 6:21 am
24000 how can one person spout so much bumcome ?
That counter must be wrong :?
Caging eh? Bit of used steel from the scrappi and you've got a place to keep your gimps too
Only thing with the bars is people can stick there hands through
And get it chewed off
If it's mesh then they only loose fingers :)
bigjohnthomas
Re: Van Security
Postby hughesyn » Tue Jul 31, 2018 7:55 am
Get slam locks or dead locks fitted to the side and rear doors and a rep lock for the drivers door.
Go to an expert, they should also install a little metal plate on the sliding door.
Slam locks disconnect the handle mechanism and replace it with a key. This means if the drivers door is unlocked with a pick, and the central locking unlocks all doors, the doors still need a key to open.
Dead locks just add an extra lock on the door for the same reason, you just have to remember to lock it.
They can help peel and steal if fitted high up.
Drivers door rep lock is because the pick device is easily available and lots of tea leaves have them.
It'll cost a few hundred quid, but without them you might as well leave the doors unlocked.
Van vault is a good idea for smaller expensive stuff.
2023 Mk8 DCIV 170 auto L3H2
hughesyn
Re: Van Security
Postby bigjohnthomas » Tue Jul 31, 2018 8:03 am
Well i rung every criminal and every locksmith in Lincolnshire
And no one could get in my van with standard Ford lock on it
Bunch of cungs :x
But then i had i feelin
If we remove the ceiling ....
viewtopic.php?f=5&t=97570&hilit=Keys+in+back
bigjohnthomas
Re: Van Security
Postby woodbutcherbower » Sat Aug 18, 2018 11:35 pm
I have a Hykee deadlock on the drivers door, plus two deadlocks on each cargo door - one at the top, one at the bottom. Also shopped around and picked up a public liability policy which gives me £10k in tools cover.
woodbutcherbower
Re: Van Security
Postby bigjohnthomas » Sun Aug 19, 2018 6:39 am
Transit are not like humans they can neither be created nor can they be destroyed
Hope this helps
The great swami allcock
boomshanka :D
bigjohnthomas
Re: Van Security
Postby hughesyn » Sun Aug 19, 2018 10:32 pm
woodbutcherbower wrote:plus two deadlocks on each cargo door - one at the top, one at the bottom.
Two seems like an advert that you have expensive stuff in the van!
hughesyn
Return to Transit Talk
cron
