djswampy wrote:. My licence says I can tow a car (van) and trailer combination of anything so long as my train doesn't exceed 3.5 tonnes and the trailer isn't more than the car (van). the rating plate says:
Gross vehicle weight (box 27) 3300KG
Gross Train weight (box 26) 5300KG
BigNeil wrote:you should go and weigh your van with a full tank of diesel etc. so that will give you peace of mind.
djswampy wrote:If I did have a licence to cover it though, The van has a max train weight of 5300kg, that would mean then that if the max van weight is 3300kg, I can only tow a trailer of 2000kg max load. Which makes my part owned car trailer useless to me unless I had a 7.5 tonne lorry.
