Mk7 engine mounts 2.2 TDCI 110
Postby markwatles » Fri May 17, 2013 10:39 am
Can anybody advise if this is correct?
First picture shows 3 nuts on offside engine mount. Second passenger side shows only one and two 'bare' bolts. Should they be like this or is it a Transit Eunuch. (two nuts missing).
Thanks in advance.
Mk7 110 T280 Trend
markwatles
Re: Mk7 engine mounts 2.2 TDCI 110
Postby algieboy » Fri May 17, 2013 1:09 pm
Mine is the same :shock:
algieboy
Postby ake » Sun May 19, 2013 8:20 pm
The two outer ones are bolts, inserted from below into threaded holes.
The middle is a stud in a smooth hole, hence the nut.
