Looking to buy a Transit and wondered what I'd be getting for this money? Seen some clean low mileage 11 reg but they're the 85 ones, are these underpowered?
Currently got a Vivaro that has had troubles so looking to get rid, cheers.
Tyrone101 wrote:I have a MK6 04 - 90ps Duratorq with low geared diff - She has and will pull 3 tonne on the back. All out hp means nothing when it comes to towing real loads on these vans. Driving style/gearing/torque/tyre pressures/trailer quality/bearings/distribution all come into play when pushing tripple axel trailers and heavy loads.
A fancy 140hp common rail transit with those shitty flywheels and weaker 6 speed gearboxes mean nothing when it comes to towing. Thats unless you are just pushing around small/medium sized trailers which a 1.3cdti combo could do.
ake wrote:Tyrone101 wrote:I have a MK6 04 - 90ps Duratorq with low geared diff - She has and will pull 3 tonne on the back. All out hp means nothing when it comes to towing real loads on these vans. Driving style/gearing/torque/tyre pressures/trailer quality/bearings/distribution all come into play when pushing tripple axel trailers and heavy loads.
That's a load of old shite if ever I heard it, quite apart from anything else, the 90 ps has the 'shitty' flywheel as the 140 ps. Furthermore the higher output engines have higher trailer weights.
limitedblack wrote:ake wrote:Tyrone101 wrote:I have a MK6 04 - 90ps Duratorq with low geared diff - She has and will pull 3 tonne on the back. All out hp means nothing when it comes to towing real loads on these vans. Driving style/gearing/torque/tyre pressures/trailer quality/bearings/distribution all come into play when pushing tripple axel trailers and heavy loads.
Does that mean I've got a Shi**y flywheel too
