2001 mark 6
2001 mark 6
Postby Reyft » Sat May 04, 2013 12:36 pm
Looking for a buy transit
It is 170000 mile
How much it is worth
Body looking good
What points i need to check before buy?
Please give me some idea thanks
Reyft
Re: 2001 mark 6
Postby Punto443 » Sat May 04, 2013 1:10 pm
Make sure it doesn't rattle when first started, There's no leaks from the diesel pump and check if its got a genuine ford fuel filter especially if its a TDCI :D
Need more details of the size and hp do a price but x-plate could be between £750-1500
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: 2001 mark 6
Postby stevo » Sat May 04, 2013 3:00 pm
Run it up to temperature, stop and re-start it to check it re-starts easy. Just drive it hard and check there are no knocks from things like the engine mounts, clutch or suspension, turn the steering lock to lock a few times and listen and feel for any noise or vibrations. Crawl underneath and check the sills and cross members for rust, also the inner arches. Look for smoke and that it idles nice and smooth.
Other than that its just regular things that you'd look for on a car. They are really rust prone but certain models have telling symptoms that point to a serious problem depending on which engine it is.
Wouldn't worry too much about the mileage, check to see if there is history and if you can, check the old mot's and see what the last one threw up in terms of advisories.
Formely ibanez2005
Your's is the new Ford Transit!
2003 100 T260 TDDi swb
stevo
Re: 2001 mark 6
Postby oldyellar » Wed May 08, 2013 10:25 pm
Punto443 wrote:Make sure it doesn't rattle when first started, There's no leaks from the diesel pump and check if its got a genuine ford fuel filter especially if its a TDCI :D
it will be a tddi on a 01 :)
oldyellar
Re: 2001 mark 6
Postby karl » Thu May 09, 2013 5:17 am
I paid £1500 quid for my 2001
Had engine rebuild at about 146000 with compressor and 110v electric alrun by PTO in 4 th gear great van
Got a bargin really as its has had loads of new stuff like starter alternator battery and 4 new tyres
karl
Tranny Lover!!!
Return to Buyers Guide
