Mk 7 engine advise please
Postby revvinkevin » Sat Oct 03, 2015 9:44 am
Hi, im looking to buy a mk7 350l either a 140 or a 155. which engine is the best and most reliable? it will be a 09-12 with 70-100 k on it.
Id be very grateful of your opinions and advise
Thanks Kev
revvinkevin
Re: Mk 7 engine advise please
Postby blue estate » Sat Oct 03, 2015 9:58 am
Get a euro 4 140 2.4 no oil pump issues like the 2.2 and more grunt
72plt MG 5 ev estate Battery car
blue estate
Postby ake » Sat Oct 10, 2015 10:33 pm
revvinkevin wrote:Hi, im looking to buy a mk7 350l either a 140 or a 155. which engine is the best and most reliable? it will be a 09-12 with 70-100 k on it.
Thanks Kev
155 never came out until late 2011
Postby revvinkevin » Sun Oct 11, 2015 7:38 pm
Thanks for your replys.
I have been offered a 2012 61reg 155 but after reading comments im not sure it they are as good as the 2.4 euro 4 engines I need to carry 2 motorcycles tools 205 ltr of water pressure washer etc etc and then hook up a 4 berth caravan.
Do you guys think the 155 is good or should i hang out and pick up a 2.4 140 ?
I have a 2003 100hp fwd at present and it struggles up the hills!
revvinkevin
Postby ake » Wed Oct 21, 2015 8:55 pm
revvinkevin wrote:Thanks for your replys.
The 155 is good, but probably harder to find!
Personally I don't think there's much difference
Postby mk7citylink » Fri Nov 06, 2015 12:29 am
Hi guys i have a mk7 2.4 115 jumbo transit
is there any common faults i need to check for? just hit 115k what bits of the engine would you advise replacing?
mk7citylink
Return to Buyers Guide
