Gear ratio...
Gear ratio...
Postby ratata » Sun May 24, 2009 10:31 pm
Hello folks!
First I want to apologize for not searching previous topics in this matter, but thats just because Im a Swede and dont know really WHAT to search for...or the correct words for it (Im a Swede). Anyway, I have 06' 115 bhp 5 gears Transit. Its a motorhome. When travelling at 90 km/h (56 mph), the rpm is like 3 000, or slightly over. Its far to high, it makes you to want to wear ear-muffs. It MUST get lower! So, here are the Q's:
1. How can I tell our current rear axles gear ratio?
2. Where can we find different pinions for the rear axle?
3. When we find those pinions, should we go for the highest ratio or the second highest? From what I understand, this engine comes with three different ratios with this gear box and rear axle...and I belive I have the lowest ratio EVER made! :D
I hope I didnt confuse you all with my 'Swenglish'.
Rockn'roll to you all
Lotta and Joakim from Sweden
ratata
Re: Gear ratio...
Postby coconut » Sun May 24, 2009 10:41 pm
1, put your VIN on here and we can look it up on etis to get the van details (or goto the etis website and sign up for free)
2, couple of different ways, replace complete axle, replace diff assembly or replace crownwheel and pinion
3, Depends what you do with it, lots of motorway driving, round town driving etc :?:
simple really :D
p.s. you probably talk better english than I do :wink:
I miss my 'courtesy van'............140 Glx..now a Jumbo :(
coconut
Ford Technician
Re: Gear ratio...
Postby ratata » Sun May 24, 2009 11:50 pm
-> 'coconut': -hmm...VIN-code, you say. All this German is gibberish to me, but I think VIN-code is "Fz-Id.Nr" in German. It's WF0AXXTTFA5D44442. I know you gave me a link, but I feel safer a pros checking it up! :D
Anyway, the vehicle will be seen mostly on motorways, and very rare on onkel Jims meadows...
Happy happyhour
ratata
Re: Gear ratio...
Postby MinorMatt » Sun May 24, 2009 11:54 pm
ransit 2000, 2.4L Duratorq-TDCi (115PS) - Puma, Diamond White 73
VIN Number: WF0AXXTTFA5D44442
Primary Features
Build Date: 26.11.2005
Vehicle Line: Transit 2000
Cab Style: Single Cab (2 Door)
Series: 350M Series
Engine: 2.4L Duratorq-TDCi (115PS) - Puma
Transmission: 5-Speed Manual - MT75
Drive: LHD RWD
Axle Ratio: 5.13
Emission: Light Duty Truck Stage III
Air Conditioning: Manual Air Conditioning
Territory: (+)"D"
Paint: Diamond White 73
Interior Fabric: Stylize (-B-C)
So its a 5.13, which is pretty low. You really need to look for a 4.63 axle
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Re: Gear ratio...
Postby ratata » Mon May 25, 2009 12:08 am
MinorMatt wrote:So its a 5.13, which is pretty low. You really need to look for a 4.63 axle
:D
Well, at least I didnt have the 5.88 axle! :D Theres only one way to go now, the 4.63! Thanks MinorMatt!
Since England is the major county in EU for Transit's, and Swedens the minor, where can I get the gearwheels for this? Do you guys know where I can ask for the 4.63 cogs?
ratata
Re: Gear ratio...
Postby ratata » Mon May 25, 2009 12:11 am
...or (I forgot to ask this), is it possible to simply exchange the gearbox to a 6-shifter?
ratata
Re: Gear ratio...
Postby ratata » Mon May 25, 2009 11:45 am
I found this rear axle: WF0LXXGBFL1G86993. Is this axle of any use to me? I know its a single wheel axle, but maybe the crown wheel and piniong are the same? :?
ratata
Re: Gear ratio...
Postby MinorMatt » Mon May 25, 2009 12:58 pm
Transit 2000, Duratorq DI 2.4 (120/125PS), Pepper Red (Metallic)
VIN Number: WF0LXXGBFL1G86993
Registration Number: SWD497
Registration Date: 01.01.0001
Registration Country: SE
Primary Features
Build Date: 29.08.2001
Cab Style: Regular Cargo Van
Series: 350M Series
Engine: Duratorq DI 2.4 (120/125PS)
Drive: LHD RWD
Axle Ratio: 4.63
Territory: (+)"S"
Paint: Pepper Red (Metallic)
Interior Fabric: Stylize (-G-C)
Spot on, just what you need! It will be easier just to swap the whole axle rather than playing with the diff.
I like the registration date though!
2 x 2006 Mk7s
Re: Gear ratio...
Postby ratata » Mon May 25, 2009 1:15 pm
MinorMatt wrote:Spot on, just what you need! It will be easier just to swap the whole axle rather than playing with the diff.
Ok! But what about the hubs? This is a single wheel axle, mines a double. Are the hubs replaceable?
ratata
Re: Gear ratio...
Postby coconut » Mon May 25, 2009 2:19 pm
The axle casings are different for twin and single wheels so you cant just swap the hubs :(
As for the CWP (cogs :) ) they look the same for twin and single wheel but ive never tried swapping them :!:
Changing to a 6 speed wont make any difference unless you put the rear axle from a 6 speed in as well ( you could go as low as a 3.77 then which would be about 1800rpm at 50mph 8) )
coconut
Ford Technician
Re: Gear ratio...
Postby ratata » Mon May 25, 2009 3:08 pm
coconut wrote:The axle casings are different for twin and single wheels so you cant just swap the hubs :(
This means I will still have to swap cogs in hte diff since the casings are different. Minor problem! I guess I will have to measure up some shims when the works done though.
However, 1 800 rpm at 50 sounds neat!! :D
ratata
Re: Gear ratio...
Postby coconut » Mon May 25, 2009 3:11 pm
You need to get someone who has done diffs before as the rolling torque, pre-loads and back-lash needs to be done by adjustments not shims :!:
coconut
Ford Technician
Re: Gear ratio...
Postby ratata » Mon May 25, 2009 3:14 pm
coconut wrote:You need to get someone who has done diffs before as the rolling torque, pre-loads and back-lash needs to be done by adjustments not shims :!:
Got it! Thanks for all the help! Ill get back to you when the works done, and Ill tell you the outcome of it!! :D
Second part of the agenda is to cover the vehicle in asphalt!! :D
ratata
Re: Gear ratio...
Postby ratata » Mon May 25, 2009 5:15 pm
MinorMatt wrote:I like the registration date though!
This car was given to Jesus on his day of birth. It took another 34 years before he could drive it, because back then, they had a hard time deciding what was left and right. This made Jesus to fail 16 times before holding his drivers license. If you look carefully at the vehicle, you will see that even when he got the license, something went wrong. The car ended up smashed in Ådalen in Sweden after a long trip from Syria. Dont ask me how it got here, but now I got an ancient rear axle!! :D
ratata
