mk2 and mk3
mk2 and mk3
Postby fortyeight » Wed Oct 24, 2012 1:24 pm
hi can anybody tell me if a mk2 and a mk3 master cylinder are the same cheers
fortyeight
Re: mk2 and mk3
Postby AlanN » Thu Oct 25, 2012 6:55 pm
This is my MK3 AP master cylinder, anything like a MK2?
Re: mk2 and mk3
Postby Muttley » Thu Oct 25, 2012 7:07 pm
Yes it is, but it aint that simple :( There are so many variations in bore size and pipe sizes that you really need the number off the little tag that hopefully is still attached :)
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Re: mk2 and mk3
Postby fortyeight » Fri Oct 26, 2012 10:55 am
mine look like that, im asking in case i need to replace them, as im having ishews with the brakes and wondered if they would fit the mk2 servo master cylinder stait swap as i cant get hold of the mk2 ones without buying new silly money,cheers
fortyeight
Re: mk2 and mk3
Postby FredTransit » Fri Oct 26, 2012 12:48 pm
it won't fit mate, but the whole servo/master from a mk3 will. I think bungle found the LDV fits but don't know which model (presumably the convoy). Either way you are looking at new brake pipes unless you go for like for like
FredTransit
Mk2 Trannyist
Re: mk2 and mk3
Postby Altransit » Fri Oct 26, 2012 12:51 pm
My 1988 Sierra one looks similar, if that's any help :?
Re: mk2 and mk3
Postby Muttley » Fri Oct 26, 2012 9:13 pm
They all look similar, differences are the distance between the mounting holes and position of brake pipe outlets and bore diameter. I found there were 5 different types of m/cyl fitted to my 1987 MK3 and 3 types on my 1982 MK2, they all looked the same though :wink:
Muttley
Re: mk2 and mk3
Postby fortyeight » Mon Oct 29, 2012 1:37 pm
hi can u put some more pictures on showing above where the pipes go on the servo and the pipes coming out of the master cylinder to the cylinder above the servo because looking at this it looks like mine as this type on cheers
fortyeight
Re: mk2 and mk3
Postby fortyeight » Thu Nov 01, 2012 9:19 am
hi taking a closer look it is different to the mk2 ,on the mk2 the resovoir is srewed on with 2 screws
fortyeight
Re: mk2 and mk3
Postby AlanN » Thu Nov 01, 2012 10:37 pm
Some Mk3 ones are the screw down type too
Re: mk2 and mk3
Postby vidma&tas » Thu May 23, 2013 9:54 am
So did anyone tried this swap?
Found couple links of one, witch I think is same as mine on mk2 :
http://www.autopartoo.com/oem/metelli/202171vu2.html
http://e-shop.eoltas.lt/index.php?cl=de ... hauto=8728
It seems cylinder wont fit on servo?
because of mounting points or shaft length or else?
(just had mine painted, actually master cyl also repaired, but now wont bleed through and has strange step when pressing pedal in middle.)
vidma&tas
Re: mk2 and mk3
Postby fortyeight » Thu May 23, 2013 2:34 pm
anyway i got a replacment master silander and servo but not needed as i think the problem as been solved
fortyeight
