AndyG wrote:Water pump is giving you warning of retirement
When was the timing belt last changed
Maybe worth doing them together
OuterMongolia wrote:AndyG wrote:Water pump is giving you warning of retirement
Is the water pump a big job then ?
OuterMongolia wrote:I have no choice except to get it sorted otherwise the engine will be ruined I assume ? Does the contamination ruin the timing belt ?
