loot34 wrote:I think that just means connected, your patch failed so after the last day ids will tell you to fook off you will probably need to reinstall ids and patch it correctly but due to registry it might not work again unless you format a new fresh copy of xp on the laptop
Least you know it all works
Not sure about the actuator, maybe it is getting obstructed just check it is free and the circlips aren't catching etc.
Regarding the injector leak off test you can't really do it with ids, ids will do a test and increase the fuel pressure and you go and look in the engine bay for leaks etc, if you had the vehicle measurement module (vmm) which you don't, you could measure each injector but as it stands you need a leak off kit really.
loot wrote:Not a clue
I find that if i get any errors i reinstall xp fresh and then install ids then extract the licence etc (if zipped) to desktop then run it.
You may have a dodgy ids disk (not really had that) or the licence is from a fly clone and not compatible (although i haven't seen much of that these days) if you have the licence that asks you which ids you want to patch them use the bottom option high quality vcm.
furnitureman wrote:loot wrote:Not a clue
Hi Loot i did click on the bottom option high quality i re read another post that said if it fails keep pressing x and it seemed to go through and finished instaling then rebooted is there a way to check licence remaining on the ids ?
loot wrote:furnitureman wrote:loot wrote:Not a clue
Yes ids connection tab, top left, them just look for a page that has the ids settings, 1 option is ids licence, it should show none for all except user xxxx.
