Transit MK7 key remote playing up
Postby ferik85 » Fri Sep 22, 2017 7:56 pm
Hi guys, I've just bought a used van and I'm experiencing problems with the remote. Sometimes it doesn't works at all, sometimes I had to press few times and sometimes it works without any problems. It's just very random. I have bought a new battery for under the drivers seat but problem has persist. Any ideas where to look next? thanks
ferik85
Re: Transit MK7 key remote playing up
Postby blue estate » Fri Sep 22, 2017 8:06 pm
Do you own a RWD van ? if so check the front battery under drivers seat it may be going dead
blue estate
Postby ferik85 » Sat Sep 23, 2017 10:31 am
Hi, yes it's RWD, I have installed brand new battery but no luck.
ferik85
Postby Altransit » Sat Sep 23, 2017 10:37 am
ferik85 wrote:Hi, yes it's RWD, I have installed brand new battery but no luck.
RWD has two batteries, which one did you replace :?:
Postby blue estate » Sat Sep 23, 2017 10:45 am
There should be 2 under drivers seat , Front does lock ecu etc
have you had any dash problems ?
blue estate
Postby ferik85 » Sat Sep 23, 2017 5:08 pm
I replaced front battery as it was flat. Not sure if it has something to do with it but van sometimes wont start. I can't even hear starter just strange noise coming from under the seat. I'll have a look tonight for any bad connections.
ferik85
Postby blue estate » Sun Sep 24, 2017 11:43 am
ferik85 wrote:I replaced front battery as it was flat. Not sure if it has something to do with it but van sometimes wont start. I can't even hear starter just strange noise coming from under the seat. I'll have a look tonight for any bad connections.
Check the voltage on the back one , the strange noise could be the starter battery cut in relay going
When you turn key to turn all dash lights on before starting there should be an audible click from under seat that turns relay on to connect both batteries
blue estate
Postby ferik85 » Mon Sep 25, 2017 11:25 pm
blue estate you helped me to solve it. I have been checking voltage of batteries to send you that information when I opened key fob I found that that battery had one of those soldered bit disconnected. For someone obvious place to look for me last one.
I have focused on that click all day, seems like van knew about it as it had no problems to start. I'll continue to check on it.
Thank you for help!
ferik85
