bambi mk 1 wrote:When was the fuel filter last changed
bambi mk 1 wrote:Pop a filter on and report back
Marting wrote:Any thoughts on the obd failure? The scanner does work as plugged it into a corsa to test its operation
MinorMatt wrote:Should be... but isn't OBD compliant. Generic readers don't work on mk6s
ned wrote:MinorMatt wrote:Should be... but isn't OBD compliant. Generic readers don't work on mk6s
I thought it was a connect the ops got N
ned wrote:Aye it was the 1.8 TDDI 75 that I assumed its a connect but I could be wrong N
Marting wrote:Sorry guys yes it is a connect
