TRANSIT STARTING PROBLEMS
Re: TRANSIT STARTING PROBLEMS
Postby MrMPuk » Tue Jan 15, 2008 9:46 pm
And it runs and starts fine once warm?
Postby daveloz1 » Tue Jan 15, 2008 10:02 pm
yeh its perfect when its not been left for a few hours
daveloz1
Postby gemini » Wed Jan 16, 2008 12:21 am
daveloz1 wrote:yeh its perfect when its not been left for a few hours
diesels running back to the tank, its drawing air somewhere
gemini
Postby daveloz1 » Wed Jan 16, 2008 6:12 pm
found anouther problem today on top of the engine where the throttle flaps are there is like a flying saucer looking valve with 2 pipes coming off one going to the throttle body and one goin to the oil filler pipe where it brethes and both of them were blocked solid do you think that will help?? what does that valve do??
daveloz1
Postby Smooth Hound » Wed Jan 16, 2008 6:20 pm
until you can find where the air is getting in, i would recommend parking it facing down hill :wink:
'94 L Reg 2.5Di LWB high top
Smooth Hound
Postby daveloz1 » Thu Jan 17, 2008 9:51 pm
hiya mr m puk as you have most of the knowlege on here somebody said to me today about checking the timing on the fuel pump they said you time it by turnibg the whole pump system is that right? :?
daveloz1
Postby AndyG » Fri Jan 18, 2008 9:54 pm
I'm thinking along these lines too :!:
Check the pipes from the fuel lift pump on the passenger side of the engine up to the filter housing, and from there to the pump carefully. See if you can tighten the connections a bit :?:
Does anyone know for sure if this problem can be caused by a faulty lift pump :?:
