Turbo pump help please
Re: Turbo pump help please
Postby transitgeoff » Tue Apr 14, 2009 7:15 am
Altransit wrote:
transitgeoff wrote: how do you adjust the mid range fueling :?:
Is this what you want Geoff?
http://www.fordtransit.org/forum/viewtopic.php?t=3968
yeh nice 8) cheers :D i thought there may have been another screw elsewhere on the pump :D
transitgeoff
Postby Jim H » Tue Apr 14, 2009 9:44 am
Hi all,
Thanks for all the advice. Hoping this week to be able to adjust the valve clearances and cam belt tension due to it having now covered 10k & will be settling down. Then most importantly advance the pump timing as Andy G excellently advised & adjust the two fuel screws as Alanwh discribed. :D :D
Will let you now the results
Thanks again, Jim
Plodding along.
Jim H
Postby alanwh » Tue Apr 14, 2009 11:45 am
Jim H wrote:Hi all,
Thanks again, Jim
Good stuff Jim :D
you shouldn't have to check the tension, as it should have the later automatic tensioner :wink: easy job to time though, it will take you longer taking the timing belt cover off :D
The cam duration is longer on the turbo to let more air in, especially on the higher revs, thats why you need a later injection.
Time it by ear. you'll notice progressively the engine note getting harsher as the turbo whine disappears on throttle. You'll get to the familiar DI Bark towards the end of the slots as Andy says.
alanwh
Postby mrepson » Thu Apr 16, 2009 10:02 pm
Andyg wrote:Guy would be one of the best people to ask, as he's actually done this :!: :D
As far as I know you adjust your 145/6 pump until it smokes under load and back it off until you have the best balance between least smoke and most power :!: (after the timing has been set :!:)
Here's one on E bayhttp://cgi.ebay.co.uk/FORD-TRANSIT-2-5- ... 240%3A1318
FORD FINIS CODE NO 1051787/1077607 ENG CODE NO 974F9A543 BOSCH NO PRINTED ON SIDE IS 0-460-414-146
is this model of pump the best one to get then,if i want to get rid of my epic turbo pump,????146 the best.???
mrepson
Postby alanwh » Fri Apr 17, 2009 8:41 am
"You need the bigger 686 pump, EITHER the 141, 145 OR 146. I have only used the 145"
alanwh
Postby Jim H » Fri Apr 17, 2009 7:07 pm
I have adjusted the pump this afternoon to Alans spec. Need to use the truck for an hour in the morning then i shall be adjusting the pump timing :D :D :D
Plodding along.
Jim H
Postby Jim H » Sat Apr 18, 2009 5:06 pm
Ok i Timed it today as advised by Andy. Heres a few picks
Standard Di timing
Drill out.
Washer plate removed(just so you can see)
Pump moved clockwise.
All done.
Now it does sound crisper & has a little more go :D but i feel that it is still not right :( .
Maybe I do need the 145/6 pump & 100PS injectors. Will this give it 100PS though ?
Plodding along.
Jim H
Postby Jim H » Sun Apr 19, 2009 8:56 pm
:D :D :D
Plodding along.
Jim H
Postby AndyG » Sun Apr 19, 2009 10:08 pm
8)
Might borrow your piccies for future use :wink:
Postby Jim H » Sun Apr 19, 2009 10:10 pm
your very welcome :)
Plodding along.
Jim H
Postby alanwh » Tue Apr 21, 2009 9:08 am
Jim H wrote:Now it does sound crisper & has a little more go :D but i feel that it is still not right :( .
Yep :)
Try and get a look at 100PS belt pully though as the slots in yours don't seem as long as mine, sure I was able to get more advance :? unless it's the pic, or I need new glasses :lol:
alanwh
Postby Jim H » Tue Apr 21, 2009 8:21 pm
Alan,
i've turned this pump up now to 3 on the overall & 2 on the mid range. it finaly has some grunt & a bit of smoke. Trouble now is i can' turn the tick over down enough so i believe this pump is realy not up to the job. I have ordered a 145/6 pump though. Also that advance on the timing has made it harder when cold to start ie it cranks over a few times rather then just starting instantly like befor. i supose i'm gettin there slowly(excuss the pun) :D :D :D
Plodding along.
Jim H
Postby alanwh » Tue Apr 21, 2009 9:21 pm
Jim H wrote:Alan,
Yep sounds like it Jim,
The more you turn it up, the more it squeezes the injection timing.
Let us know when you get the pump as you can up the boost a bit too :wink:
Edit.. You'd need 100PS injectors tho :!:
alanwh
Postby Jim H » Tue Apr 21, 2009 9:54 pm
Nice one Alan,
I will go for 100ps injectors as soon as i can aford 'em. Just spent a chunck on that pump & a nice stainless exhaust for me bike :D
Plodding along.
Jim H
Postby Jim H » Sun Apr 26, 2009 6:54 pm
The new pump arrived Friday. Just need to find time to fit it :?
Plodding along.
Jim H
Users browsing this forum: shonkers
