remove light switch
remove light switch
Postby Osty » Sun Dec 11, 2011 5:07 pm
I want to remove the main car light switch on the dashboard, I think I have a bad contact in the high light control wheel, some times the light do not go fully up again.
Therefore i would like to clean this swith, if possible ?
Is there a manual available
Ford transit 2005
Osty
Osty
Re: remove light switch
Postby angeleye » Sun Dec 11, 2011 8:31 pm
you need to take instument panel out (speedo/rev cluster) as the screws(3) that hold the vent /switch panel is behind this
a haynes manual will serve you well,
is it both lghts that do not function right :!:
angeleye
Postby Osty » Mon Dec 12, 2011 7:03 am
Thanks,
I had a look for the haynes manual but did not find the transit 2005.
the small wheel to move the lights up or down ( next to the light switch) is working but when on 0 the lights are not fully up, I have to play with the wheel before the lights are fully up, I want to clean the control wheel with contact cleaner
Osty
Osty
