Brains Mk6 transit wrote:Did the locks lock then unlock before you pressed the fob
Brains Mk6 transit wrote:If you only have a lock on the drivers door then you have CL then if it works using the key in the lock then it should do the cycle. I usually do the on off thing pretty fast.
ake wrote:The instructions you have posted are for Ford cars, not Ford Transits. On Transits you must key on and off 8 times, there will be no chiming noises
winterheating wrote:the doors cycle to tell you its in programming mode instead.
jwer23 wrote:Just to update this thread, I've just programmed a new remote for my 2002 T280 having lost my old one, and the only procedure that worked was:
With Van unlocked;
Cycle ignition key rapidly from 'off' to 'on' leaving in 'ON' position on 8th time
Wait for locks to cycle
Press button on remote
Turn ignition off
Job done! Van unlocks with remote again
Van with a Man wrote:Hi All, and thanks 4 U`re help, have I missed something, do these proceedures work for programming the Ignition in the ingnition lock and starting, ( this is my problem ) ?? the doors do unlock no problem. ??
