Mazlyn wrote:I have exactly the same problem with the exact same van here in Sydney, I changed the air flow sensor and problem went away for a couple of months, now it has returned so I am going to change it again. The only difference this time is that it does actually run on for 20 seconds or so after I with it off and its not the Turbo Cooler.All help would be massively appreciated
Run on will probably be the ESOS, do a search on here, its been covered before.
